Is it possible to repair pipe threads...NPT?
Discussion in 'The Hokey Ass Message Board' started by Tcoupe, Mar 24, 2005.
  1. Tcoupe
    Tcoupe
    I have a 1/8 27 NPT hole that accepts an oil gauge fitting...its aluminum, it will tighten up, but leaks...I tried to tighten more and it started to feel loose. So the question is...can I fix it...tap or heli-coil. Any help would be greatly appreciated!
  2. av8jon
    av8jon
    The threads are probably junk. I'd drill it out and run a 1/4 pipe tap in it for new threads then use a 1/4 to 1/8 pipe reducer to get back to 1/8 pipe.
    I hope this helps,
  3. tommy
    tommy
    The easiest way would be to drill it out and tap the hole with a 1/4" npt. Then use a 1/4 x 1/8 npt bushing. Pipe threads are tapered. I've never seen a heli-coil for pipe threads.
  4. I concurr.. No such thing as a helicoil for NPT since it is a sealing thread. Since it's an oil fitting you DO NOT want to rig it with epoxy... Drill and retap one size up.
  5. Comet
    Comet
    I had the same problem in br*** once. Most better auto parts stores will carry NPT tap sets. Be careful to not get shavings in the oil, or it could become a much more expensive problem!
  6. McGrath
    McGrath
    Have you tried Teflon Tape on the threads? Sometimes if a bare pipe joint leaks, a few wraps of teflon tape will seal the threads. You can get a roll of it at the hardware store for about a dollar.
  7. roaddevil
    roaddevil
    as brought up before i would punch it out a bit and run a touch bigger tap in it and then reduce it down. i think this is your best bet
    Permatex makes a tread repair kit it works well on fixing stripped out holes just be carefull it can make a mess quit and really look like hell if done carelessly, and its not a big fan of vibration. Only use this in case it cant be punched out its easy to F#@K up
    IF you didnt have Teflon Tape or pipe dope on all pipe threads that are holding a fluid or air that just lack of common sence.
  8. Rand Man
    Rand Man
    Tape won't fix stripped or dammaged threads. The treads are the sealing surface.
  9. Tcoupe
    Tcoupe
    Thanks for the help guys....I think I am screwed though, the stripped threads are actually inside the oil pump and the fitting holds a check ball and spring...so drilling is out of the question and I dont think I want to put any thing on the threads that I why I was hoping I could repair it some how....anyone have an oil pump for a 72 sportster!?!
  10. JOECOOL
    JOECOOL
    I know you probably don't want to hear this but you may want to TIG it full and retap it.
