Whats the best "trick" or tech tip a mentor showed you?
Discussion in 'The Hokey Ass Message Board' started by The Mandrill, Jan 11, 2010.
  1. Adam.Perrault
    Adam.Perrault
    from Phoenix AZ
    Seems like a waste of bacon grease.
  2. 51pontiac
    51pontiac
    from Alberta
    Really simple - words of wisdom from my dad.
    when you take a wheel off a car, slide it under the frame - even if it is on jackstands. Can't hurt but can save your life.
  3. The most basic one I use every time with a threaded fastener....spin it backwards slowly til you feel it drop a bit and your threads will be perfectly aligned, then spin it forward. Always turn it backwards first and you won't have stripped threads.
  4. I hate seeing guys fumble with distributors on modern engines to adjust timing when starting a fresh engine.
    100% guaranteed way to start that fresh engine on the first twist of the key:
    1) make sure the #1 cylinder is on the compression stroke. Either put a finger over the spark plug hole while rotating the engine by hand, or watch the rocker arms. When the intake rocker goes down you're ****ing in air, then the rocker closes and you're comin back up on the compression stroke.
    2) as the piston is coming up to TDC on the compression stroke STOP rotating the engine when the timing marks line up to the timing you want to run. On my small block Fords 10 degreees works great.
    3) put a sparkplug in the end of the #1 sparkplug wire and ground the plug to the engine.
    4) now you can drop your distributor in place with the rotor pointing to #1 terminal. keep in mind the rotor will spin just a bit as it drops into place.
    5) get some power to the coil, either with the key on or with a jumper wire from the (+) terminal of the battery.
    6) slowly rotate the distributor back and forth til you see a spark, then tighten down the distributor at the point where the spark occurs.
    The timing should be 99% dead-on, and if you've filled the carb bowl(s) with fuel it should only take a couple pumps or small squirts of gas to get the engine to fire.
  5. Bad Eye Bill
    Bad Eye Bill
    from NB Canada
    Never leave the shop for at least an hour after cutting with a torch or doing any welding.
    Boneyard51, blowby and pat59 like this.
  6. mixedupamx
    mixedupamx
    EASTWOODS sells a heat sink putty
  7. 1x9g
    1x9g
    My Uncle HamBone Lived next door to us, was always working on old cars in the 60's and 70's from the 40's and 50's and got me involved tinkering with cars. He knew where every tool was in his garage. I was working on my car and had only a few small hand tools, and the ones I did have were not in the best condition so when I needed a tool I would go ask to borrow the tool and he always said okay. One time I didn't return the tool when finished,so when he needed it and it wasn't there he wasn't very happy. Next time I needed a tool and went to borrow it I told him i would return it when finished and treat it like my own. He stopped me right then and told me not to treat like it was mine that these tools was his damn tools. I learned a good lesson that day and from then on respected others people and my own tools. This is only one of the many tips he taught me. I now have tools that Iv'e owned for 30 plus years.
    Thanks, Ross Gould
    Build it
    Race it
    Wear it out
    Repete
  8. chevelle bob
    chevelle bob
    from Linton
    This is one I need to follow! thanks
  9. 29AVEE8
    29AVEE8
    This is exactly how my dad showed me more than 45 years ago. It will start right away, no screwing with the distributor and timing it by ear. When you get the cam broken in and put a light on it it will usually be dead nuts on the correct timing or (in my experience), never more than one degree out.
  10. mixedupamx
    mixedupamx
    MAKE SURE TO SPIN THE DRILL BIT WITH YOUR FINGERS NOT A POWER DRILL!!!!!! I saw the results at work when an apprentice was given this advice and not told to spin the bit MANUALLY:eek::eek::eek:
  11. mixedupamx
    mixedupamx
    when installing a fuel pump on a small block chevy smear axle grease on the pump rod and insert in the block. this will keep the rod from dropping out while you install the pump. the grease will disolve in the oil
  12. Greezeball
    Greezeball
    Yep this is the hot damn sure fire method never fails no guessing.
  13. I remember watching Boyd Coddington's crew trying to start one of their projects and just laughing out loud...even my wife knew they were screwing it up :D
  14. modeleh
    modeleh
    when using gasket punches, set your material on the end of a block of wood, not the side. the end grain is softer and will allow the punch to cut through the gasket nicely and you won't damage the cutting edge of the punch.
    if you need to fill a hole from an emblem or trim, an easy way is to insert a nail in the hole from the back side, it mostly fills the hole with metal, then just weld it and grind.
    and for those of us that need to shovel snow... stick your metal shovel in the woodstove door for a minute to warm it up, then melt some old candles on it. the snow just slides right off.
    and to quote an old timer I knew... "that'll come in handy, whenever ya use it!"
  15. AAFD
    AAFD
    from US of A
    Put a condom in the spark plug hole and fill it up with air to hold the valves up. Balloons work too, but you need the thick ones so they don't pop. Plus you always look cooler buying condoms rather than balloons. ;)
  16. wheeler.t
    wheeler.t
    Tight is tight and too tight is broken.
    Ace61 likes this.
  17. nachodog
    nachodog
    from socal
    If you need to borrow the same tool twice it's time to buy one. The best tip ever though is to keep all your tools clean and organized. And nothing is so easy that it can't be done wrong, so pay attention to what you're doing and what you've done.
  18. HambBurglar
    HambBurglar
    from Cincinnati
    Back to the sharply cut wire ties. Grab the wire tie with linesman's pliers even with where it p***es through the locking end. It will twist off below the end of the lock.
    Whenever someone smashes a finger at work it is always suggested to go home and
    soak it in cider.
  19. atch
    atch
    cures many ills.
  20. I thought it was soak yourself with hard cider? :D
  21. happy hoppy
    happy hoppy
    we know the copper or br*** backer trick for filling holes and we all remove paint before welding but, don't forget to run a drill bit into the hole to get any rust or paint off the inside edge. makes for a cleaner weld.
  22. Van Dutch
    Van Dutch
    Adjusting sagging car doors to fit better, wihtout doing damage, using a 2X4.
    Thanks Henry Bond.
  23. Van Dutch
    Van Dutch
    And how to use pop rivets very effectively with stop signs. Thanks Big Willy McNabb.RIP
  24. atch
    atch
    i've seen a Ford repair manual from way back (30's or 40's) that illustrates how to do this. seems quirky, but it works.
  25. vagabond407
    vagabond407
    Lil' fire and candle wax!!!!
    Mark
  26. toolman1967
    toolman1967
    I seem to always find Phillips heads screws that will not come out. If I can get to the sides of the head I attach vise grips to it, usually the head is hidden on the sides though. I use a center punch and small hammer. Position the center punch on the side of the head and tap in a counter-clockwise direction. This usually will loosen it so I can use a regular Phillips head screwdriver to get it out the rest of the way. I usually find these stubborn screws on the switch housings and float bowls of motorcycles.
  27. steveo3002
    steveo3002
    from england
    another one for phillips head screws , dip the screwdriver in valve grinding paste to give it some grip
    for allen /hex socket bolt heads that are starting to round , take a dot punch and and hit it on each side of the hex , with some luck it will close it up enough to make the tool hold
  28. knucklepower
    knucklepower
    from .
    Old rubber parts are like new when they are washed with old Jean clothes in the washing machine at 60 degrees. Cracks go away like this, of course not.
  29. atomickustom
    atomickustom
    It already sort of came up, but to do the final block sanding you take TWO paint sticks, tape them together, then wrap a whole sheet of wet-or-dry sandpaper around it.
    It's a lot easier to hold onto than one stick, but the two flex just enough to follow gradual body curves.
    My dad was a bit of a hack but his cars were always straight as an arrow when he painted them, no matter how much bondo he put in them. This is how he did it. Personally I laugh at the schmancy tools Eastwood sells to accomplish the same thing. Maybe for a full-time body shop they're worth it, but for someone who paints a car once every couple years the "two sticks and a bit of tape" block works fantastic!
  30. BigBossMan
    BigBossMan
    If like me you only have the weekends to work on the car and things seem to be progressing very slowly, take photo's at the end of each session.
    This way you'll notice the progress as you look back through your older photo's.
    If you come across a problem with the project, take a photo and set it as your desktop picture on your pc. This way you'll be reminded about it every day until the next 'garage day' and you'll have more time to solve the problem and might even come up with a better solution than you originally thought of.
