im i the only one who still gas welds?
Discussion in 'The Hokey Ass Message Board' started by HELLVIS, Mar 7, 2011.
  1. HELLVIS
    HELLVIS
    dont anybody who gas welds anymore do you?
  2. DamnYankeesKustoms
    DamnYankeesKustoms
    not up until recently, figure its the closest I'll get to owning a tig welder for a while, what are you welding?
  3. I have been doing sheetmetal work recently with a little jeweler's torch. It works great! So, no, you aren't the only one, haha!
  4. Sheep Dip
    Sheep Dip
    from Central Ca
    I don't think most guy's know how plus with all the tig's, mig's and spool guns it just isn't applicable any more, produces way to much heat, but I do know a muffler man who still gas welds all his work.
  5. DamnYankeesKustoms
    DamnYankeesKustoms
    looking into welding aluminum and stainless, can anybody offer any tips??
  6. 296 V8
    296 V8
    from Nor~Cal
    Is it just me or do you sound like the gas is getting to you? :rolleyes:
  7. fleet-master
    fleet-master
    gas weld a lot...my preferred way to weld sheetmetal panels.Quicker than a tig and nice and maleable so can file finish easier. I use mig for the structural stuff where plugging spot welds etc tho...check out my build thread! :D
  8. Sheep Dip
    Sheep Dip
    from Central Ca
    Stainless I don't think is possible to gas weld but you can weld aluminum with a very low oxidizing flame
  9. iammarvin
    iammarvin
    from Tulare, Ca
    Was able to do it a decade ago, tried it again tonight........failed, miserably.:(
  10. tommythecat79
    tommythecat79
  11. Offy 220
    Offy 220
    I have TIG and MIG Welding machines, and also my reliable gas welding set. I use all three but my favorite is gas welding, especially if I am replacing panels or small sheet sections on the body I am repairing. I was taught gas welding at a young age and after 35+ years of welding, I still feel comfortable using a torch. I would rather use a torch and hammer weld a panel than TIG. Just my .02 cents. :)
  12. DamnYankeesKustoms
    DamnYankeesKustoms
    Love o/a welding, it's about a traditional as you can get....
  13. peter johnson
    peter johnson
    I still do! I taught my boys to at 11 and 13yrs old,best way to start!P.S.they kicked *** at school in metal work when it was time to gas weld and told teacher that mig welding was cheating!!!!!
  14. KUZTOM
    KUZTOM
    On stainless use s/s bicycle spokes ;)
  15. Shaggy
    Shaggy
    from Sultan, WA
    Really? i laid a couple beads on SS and they looked good
    And Oxyidizing flame on aluminum? that doesnt sound right to me
  16. WhitePunkOnNitro
    WhitePunkOnNitro
    from Middle Tn
    I'm all about the torch.
  17. Torana68
    Torana68
    from Australia
    same here but its also great for all those odd little fixerupper things that come up (brazing heating cutting)
  18. Ned Ludd
    Ned Ludd
  19. The37Kid
    The37Kid
    Gas is all I can afford. I did TIG aluminum bodywork for 14 years, but still haven't had a shot at TIGing steel. Too old to get my head around MIG welding, spitting out wire without controll is just beyond me. How about the old STICK arc welding, that must really date me.
  20. Shaggy
    Shaggy
    from Sultan, WA
    I dunno about that, i just turned 26, and there are certainly a few younger guys i know that have atleast played around with it
  21. willowbilly3
    willowbilly3
    from Sturgis
    I hammer welded the whole body on my rpu. Used almost two 5# rolls of tie wire.
  22. Offy 220
    Offy 220
    Good comments 37Kid - I can relate. :) I first learned gas welding in my pre-teen years, stick arc welding in High school and saved up enough money to buy an old Lincoln 250 Arc/TIG machine. Finally "learned" MIG a few years ago - I still have problems getting the speed right. I try to stick with what I know best - gas, arc and TIG, which is similar to gas welding.
  23. chopolds
    chopolds
    from howell, nj
    I have all 3 methods in my shop. There are times when each is appropriate, better, or less time consuming. Gas seems to be the most versatile, and gives the best results on sheet metal, when you can get to the backside...I DO cut out a lot of inner structure, to get a dolly back there!
    The Tin Man, Kent White, has a lot of info on gas welding aluminum and stainless, and he is a firm believer that gas is superior to MIG and TIG on most projects. He sells fluxes, lenses, and videos on his website, as well as hand tools, and metal shaping machines.
  24. 1971BB427
    1971BB427
    from Oregon
    I used to gas weld everything 30+ yrs. ago, but haven't had a gas welder until just recently, so I MIG'd everything. Now that I've got a gas setup again, I'll do some things with it if I can teach myself again!
  25. Rocky
    Rocky
    Classified Editor
    Our old high-school shop cl*** actually had our own acytelene plant! We welded like crazy...I still use my torch for exhaust work and I'd love to buy one of those little body-work torch sets. The mig usually gets chosen for most of my welding jobs...especially frame work.
  26. cederholm
    cederholm
    I can braize pretty well but my sheet metal gas welding ****s! Any advice on where to turn? Don't realy have time for trade cl***es.
    Any of you local guys care to teach? I've got BEER!! :)
  27. silversink
    silversink
    Where have all the wire coat hangers go----my wife's famous saying. I go through the closet every once in a while looking for high tech materials.
  28. tommy
    tommy
    I welded all of my exhaust at my muffler shop for many years using the hangers that the uniforms came on. (got to keep the overhead down:D) I was in the back room and quite often the oil from the tubing would build up inside and ignite giving one hell of a back fire bringing everybody running. I use it often for carb linkages and any thing that I want to build up a pleasant fillet on. You can shape it like modeling clay.
  29. Mr48chev
    I'm hunting for a Victor J28 torch handle right now for use on the body work on my projects. I have the mig for doing the structure and getting everything squared away but then I think I would rather go with what I am most comfortable with when I weld the panels up.
  30. Tom S. in Tn.
    Tom S. in Tn.
    If I were still fabricating, I'd still use O/A to weld 4130.
    Our ch***is used to cert just as good, if not better, than a lot of TIG jobs.
    Machines used for welding have taken away an art.
    Tom S. in Tn.
