TECH WEEK!!! Home made louver dies!!!
Discussion in 'The Hokey Ass Message Board' started by bmxarmy, Mar 7, 2011.
  1. bmxarmy
    bmxarmy
    Hey guys and gals! Here is my contribution. A friend wanted a custom cover for a non hamb friendly motor (import). And he really wanted louvers pressed in it. Its funny import guys call them vents. Anyway I figured it was worth a shot, so here is how I did it.
    first I took some 1/2" plate and some 1/4" plate cut to be 3" long and welded them togeather, I didnt have any 3/4" plate. I then ground them into the ruff shape I wanted for my louver. Next I had this big ugly piece that came with my mill drill that had a big slot in it, 3" long convenient enough. I widened it up a bit and made a matching "female" die to my male approximately 1/16" bigger all the way around the male die. Now I didn't think this non-tool steel setup would punch through the 20 gauge mild steel I was working with so I carefully cut 3" slits in the steel to aid the process. I lined up the relief I cut with the female die placed the male on top and whacked it with a hammer. Needless to say it took about 4 average hits to form it right but I was very surprised with my dies. I tweaked the male die a little bit and hammered till it started to rip the corners out. I then welded on some angle on each side to work as a stop and the tool was done. The pics below will explain it all a lot better than the above ruble....I hope.
    Here is the male die. If you look close you can see the 2 piece's welded together.
    here is the bottom female die and the male without the angle iron stops along with the first demo louver!
    This is the coil cover with the layout marks.
    And here it is with the slots cut in it
    After punching one louver I realized that I would have to punch the next one way further away and that wasn't any good so I made a new "female" die which would allow me to make them 1" apart. This piece I will likely remake as did not have any thick material so its just 3/8" and will likely bend fairly easily, however I did punch 10 louvers with it and it seems no worse for wear.
    this is how it lines up after one louver is punched.
    You can see I rolled some beads into too. Buddy wants to put a sticker in there. Here is the cover with the louvers all done.
    And here it is bolted up to the RB25
    As you can see its a little bit cooler than the stock piece.
    eddie rockitnyc likes this.
  2. chaddilac
    chaddilac
  3. 510madmav
    510madmav
    this is my favorite yet
  4. slddnmatt
    slddnmatt
    thats just too easy great job!!
  5. Stutz
    Stutz
    Thats pretty awesome.
  6. toolman1967
    toolman1967
    Nice looking panel, Nice tool!
  7. mj40's
    mj40's
    It is my understanding the home made dies have to be hardened to last any time in a press???????
  8. jjayf
    jjayf
    from Yelm, Wa
    wow that engine looks MUCh better what is it?
  9. Retro Jim
    Retro Jim
    Very good tech ! That really did turn out nice too ans he will surely have the only one around !
    Maybe his friends will want to be putting in some orders for you to make them some .
    Good work !
    Retro Jim
  10. Great tech. You can harden them with Kasenit and they'll last alot longer.
  11. big creep
    big creep
  12. NealinCA
    NealinCA
    Cool deal...nice job. I am seriously thinking about making a set of dies myself. Thanks for the ideas.
    Neal
  13. Very cool. Thanks!
  14. I was just talking about this with a good friend last night.
    Thanks, this is great.
  15. DamnYankeesKustoms
    DamnYankeesKustoms
    never thought I would see one of those engines here, however you really changed the whole look of that engine, allmost looks early european, anyway those louver dies are a neat idea,
    What is that engine going in anyway?
  16. Kevinsrodshop
    Kevinsrodshop
    Tech week brings out the best in everyone. Nice idea. I'll use this one.
  17. Sheep Dip
    Sheep Dip
    from Central Ca
  18. Minewithnoshine
    Minewithnoshine
    RB25, came in Nissan Skylines, never came out here in the states, but you can get them from an importer, getting to be a popular swap for the import crowd...
    Looks MUCH better, nice job!
  19. bmxarmy
    bmxarmy
    You got it minewithnoshie!
    That is actually my swap motor. The cover is for a friends rb, when the old straight 6 got tired. I figured this would be an easy swap. And after driving my buddies car...I was sold. they make 240-260hp stock so Its gonna be alot more fun than the old 6! Thanks for all the great replies guys!
  20. oldandkrusty
    oldandkrusty
    Very impressive use of things that are easily found in most guy's garages. I like it a lot...
  21. That is a great little tool. Just curious, how are you cutting the slit? I notice some are saying the die might not last that long due to it not being hardened, but I'm thinking it just might last quite a while because it doesn't actually cut the slit, it is simply forming the thin metal. Cool tool.
  22. bmxarmy
    bmxarmy
    I use a zip cut to cut the slit, then use a small file to clean up the edges.
    I've now punched about 20 louvers with it and it seems to be holding up fine so far.
  23. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
  24. Butcher's Shop Customs
    from Paducah KY
    Awesome! I was just thinking this morning about how I wanted to louver the hood on my 61 Suburban!
    Now everyone, forget you ever saw this. My contribution will be "Louvering a 61 Chevy Truck Hood"...
  25. Rex Schimmer
    Rex Schimmer
    from Fulton, CA
    You got my vote!!! Nice and simple, makes a great looking louver and any tool that is operated with a BFH is my kind of tool!!!
    Rex
  26. rodknocker
    rodknocker
    Are you just hitting the die with a hammer?
  27. parklane
    parklane
    Very nice. Another one to remember.:)
  28. bmxarmy
    bmxarmy
    Not just any hammer a big f$#*n hammer
  29. Bumpin up this old thread, cause its awesome :D:cool:
  30. I have built a louver press as well. Here are a couple of pics.
    My latest home made tool is a louver press. 1 of many tools I have made myself. I am running out of room to store them all!!!
    Mtw fdu.
    They are about 60mm long. I have changed the hand lever to a hydraulic ram using a porta power. I have got an air over hydraulic ram for it but haven't had the time to put it on. Still in the process of finishing my cnc plasma table.
    Mtw fdu.
