Jaguar rear end info
Discussion in 'The Hokey Ass Message Board' started by HotRodrookie, Feb 10, 2009.
  1. Re captain scarlet and the 20 pages of info.
    He sent it to me and it is definitely well worth the read.
    I have altered my diff mounting in my Lincoln based on that info.
    Thanks again captain scarlet
  2. 1934coupe
    1934coupe
    Just scanned through the threads quickly, we put one in our 39 Willys sedan 28 years ago and its still in there. But you need to get new coil overs for the weight of your vehicle otherwise it will drag its ass.
    Pat
  3. Contact me, I got some input on that jag rear
  4. HotRodrookie
    HotRodrookie
    from nor cal
    Has anyone modified thier frame to bolt in the jag rear using the cage and the 4 orignal mounts?
  5. HotRodrookie
    HotRodrookie
    from nor cal
  6. fishersb
    fishersb
    Has anyone tried setting a Jag IRS on airbags and could it be done.
    Would be interesting to know how.
  7. Still nobody with airbags?
  8. I have an "S" Type Jag rear under the "T", and not mounted in the cage to give that open feel to it.
  9. zman
    zman
    from Garner, NC
    spit it out already...
  10. Dan in Pasadena
    Dan in Pasadena
    Reviving this old thread because the '46 Chevy truck I bought in August has a Jag rear end in it. At this writing I have no idea what car it came out of or if its a posi unit. But it is still in the original cage and I found this thread looking for information on replacement, adjustable coilover shocks to raise the rear end in my truck. It is a bit too low in my opinion. Any and all advice on what year/model junkyard Jag I might be able to snag adjustable ride height coilovers out of would be hugely appreciated. If that's not possible, links to good sources for replacement coilovers? I need to replace the rear rotors too as they are grooved; is there any good sources for Jag parts you know of?
    P.S. Here's the only photo of my rearend I have (this was before I pressure washed it, sorry). Note the low butt on my truck too. Gotta lift it just a bit.
  11. Looks like a very simple task of raising the catch and inch or two.
    That way it won't throw out the original set up geometry.
    Which would happen if you put in different coil over shocks.
  12. Dan in Pasadena
    Dan in Pasadena
    At the risk of letting my ignorance show, what is "raising the catch"?
  13. zman
    zman
    from Garner, NC
    still waiting on the VERY IMPORTANT info..... :D
    I need to know, I've already put about 7,000 miles on mine this year, wondering about it all the time.... NOT!
  14. Weasel
    Weasel
    Huh????
  15. captain scarlet
    captain scarlet
    from Detroit
    X2:confused::confused:
  16. bigdog
    bigdog
    Something you'll have to watch if you change ride height by changing rear springs is rear camber. The rear camber is adjusted by changing shims at the inner end of the halfshaft. I don't know how much camber change there is as the suspension moves, but if I was going to change ride height on one of these I'd start by unhooking the shocks, jacking it to the height I wanted, and then make sure that there's enough adjustment to get the camber right.
  17. Soory. Typo. Raising the CAGE.. Thought was was a no brainer really...
  18. As I said. lol. Raising the CAGE means everything stays as JAG designed it. No camber change etc.
  19. Jessefelix
    Jessefelix
    from Hanford,Ca
    here is a site where you can get parts for that jag rear end
    www.cwiinc.com
  20. Lee Borden
    Lee Borden
    I am looking for a phone number for Curt Hamilton in Van Nuys, Ca. Thanks!
    rleeborden@att.net
  21. vncruiser
    vncruiser
    Send a PM to MCM...he is good freinds with him...
  22. alexelchingon
    alexelchingon
    Curt Hamilton (818)943-2323
    Im doing a jag front and rear swap on my 51 F1 and was at his shop today. This guy knows his shit!!!!
  23. He probably found it.
    That was about 2 years ago..
