Body guys, are you familiar with Nitro Stan?
Discussion in 'The Hokey Ass Message Board' started by Bob 1743, Mar 9, 2011.
  1. Bob 1743
    Bob 1743
    I have used this product in the past & like it. Can't seem to find it locally, in or near Charlotte NC.
    Do you know of a product that applies and acts like Nitro Stan ?
  2. hotsilver
    hotsilver
    from Florida
    Its junk, I would NEVER recommend using it... buy a "two part" product. If you want something that works like it use "Metal glaze" by EVERCOAT products.
    http://www.evercoat.com/
    RJ
  3. Times 2
  4. F&J
    F&J
    I have not seen it in years, except for a tiny tube of "off brand' filler at a small hardware store. Either of these dry very slow and shrink a lot.
    It was replaced years ago by PPG acrylic putty in both green or blue. My local PPG supplier no longer carries that :(. The acrylic dried much faster and had much less shrinkage.
    Now they have the 2 part stuff you mix like body filler. I don't like it because I no longer have the time to walk around the whole car looking for tiny nicks to fill. The 2 part does not sand as well and smells bad.
    I did see some of the PPG acrylic on ebay a couple years ago, may still be on there. If you are a stubborn old guy like me and hate all this modern 2 part ****, try to find the PPG acrylic, I think you will like it.
  5. krackerjack88
    krackerjack88
    from Fresno,Ca
  6. kwmpa
    kwmpa
    from Pa
    evercoat quantam1 it can be used as filler and glaze....sands very easy 80grit sand like 40grit on regular filler.
  7. Stu D Baker
    Stu D Baker
    from Illinois
    I believe he's looking for a glazing putty, not body filler. Stu
  8. Ob1
    Ob1
    Big fan of Evercoat Quantum here. Fresh can is light and liquid, great for skim coats. As it ages it thickens a bit, so I keep 2 cans going, 1 for skims and 1 for building, but then again I use the stuff daily.
    Keep the lid tight and it stays creamy. Ultra fine filler, skim coats sand with 180.
  9. krackerjack88
    krackerjack88
    from Fresno,Ca
    Oh... Got ya! Then Quantum or Metal glaze works great. Either one I have used them and have had great success.
  10. carcrazyjohn
    carcrazyjohn
    from trevose pa
    search on line ,Alot of guys that say it s junk Use it to heavy ,Its only for scratches,I still use it ,Most of my cars are outside and no problems.Thats all they had back then ,I didnt like the evercoat stuff ,Hardens to fast in the summer heat ,Icing is great ,Made by evercoat
  11. Ob1
    Ob1
    Quantum has 2 different catalysts, hot and cool weather formulas. I almost never use the hot weather catalyst, unless I am applying it late in the day and plan on sanding the next morning.
  12. storm king
    storm king
    I used Nitrostan for years. Like Hotsilver and others have said, the new 2 part product from Evercoat is far superior.
  13. Bob 1743
    Bob 1743
    I think I will go with the Metal Glaze, but one more question. There seems to be a few part numbers for this product, # 414, # 416 etc. What is the difference in them?
  14. BJR
    BJR
    We used Nitro stan in the 1960's, it's lacquer based and will shrink for 6 months after it's applied. It was used to fill sand scratches. Keep the can on your shelf as a collector item and use the new two part glazing fillers.
  15. Ob1
    Ob1
    415 is 24oz. 416 is 30oz
  16. FiddyFour
    FiddyFour
    open the valve on your welding gas and fill the can with gas before you close it... zingo, no more oxidation.
  17. autobodyed
    autobodyed
    from shelton ct
    nitro stan went out with the hoola hoop, 2 part putty's are your friend, use only as directed.
  18. Ob1
    Ob1
    Had a buddy bring me a cycle tank to paint, had that red spot putty in it.
    Told him "Not with my paint on top of it!"
    He is very happy now that it is all said and done {with no red putty!}
  19. 41woodie
    41woodie
    I think I still have a tube of NitroStan laying around but even when it was new I hated the stuff. Shrinks like mad and loves to skin over and bait you into trying to sand it before it's completely cured. I think I'll look for it tomorrow and throw it away.
  20. 32phil
    32phil
    from New York
    Years ago it was the **** to use. I still remember walking around the car with the tube and my favorite black squeegie, it was worn down to a knife edge. I also remember wondering why I put so many spots...cause I had to wet sand them all !!!! Going to White Castle with the car in primer and red oxide spots ALL over....now that was cool.
  21. cozee
    cozee
    Quantum now has a third catalyst, Fast, light blue tube. Love it.
  22. socalmerc
    socalmerc
    from socal
  23. philly the greek
    philly the greek
    from so . cal.
    I've used Dolphin Glaze for the past several years. 2 part , easy to sand.
  24. 56oldsDarrin
    56oldsDarrin
    Me too, you can get it all out of the tube.
    my story; DP40 all laid down, Orange basecoat done, White stripe done, 1st coat of clear looking good...****, little puckering wrinkles, every bit of it backed out.
    Hundreds of dollars wasted that weekend.
    2 part putty is your friend.
  25. chopolds
    chopolds
    from howell, nj
    I agree with the rest, don't use it! It used to be the thing to do, but most guys overdid it anyway, and had terrible shrinkage after the paint was applied.
    Today's catalyzed putties are light years better!
    I use Metal Glaze, and Icing.
  26. Mike51Merc
    Mike51Merc
    Nitro Stan! I remember the smell of that stuff. It had that irresistable chemical bad-for-you scent!
  27. BJR
    BJR
    MMMMMMMMMMM White Castles nothing better!!!!!!!!!!!!!!!!
  28. kayjohn
    kayjohn
    Nitro Stan ????????? LMAO! I had to use Alot of that @#$% behind collision body men back in the early 80s. Had alot of probs and lost my *** on redos untill I got a clue and started sending the jobs back to them to finish right. beating the book was the name of the game. The shop manager started having the bodymen finish in primer. lol the tables were turned when they were the ones paying me to repaint the redos. Made better bodymen out of them. And the use of the Nitro went down filling pin holes only.
    Today it's U-pol's Dolphin Glaze.
  29. Bob 1743
    Bob 1743
    I gotta thank y'all. This is the best site for getting a straight answer.
    I guess the stuff that was used back when, isn't as good as what's out there now.
    The money we spent sending the kids to college, to study chemistry, paid off.
  30. chaos10meter
    chaos10meter
    from PA.
    Wow Nitro Stan haven't heard that term for awhile.
    I like the Evercoat 2 part products.
    I go over the body with a battery trouble light and mark the stuff I missed with a small pc. of tape or a white pencil so I don't miss them again ( but I do ) then mix small batches, you do waste some. A little drip of fibergl*** hardner will keep it open longer, why I have no clue but an old body man told me that years ago.
    Small pin holes and scratches I apply the Evercoat glaze with a single edge razor blade, really push it in. not much sanding required if applied this way.
