Small block ford pulley question
Discussion in 'The Hokey Ass Message Board' started by easttown, Mar 11, 2011.
  1. easttown
    easttown
    I have a 75 351W and want to run one V belt to turn the water pump and alternator..It has 2 belts now and a ps eliminator pulley which is in the way,so i'd like it to go...anyone know what pulleys to use? it has a 4 bolt dampener
  2. 62rebel
    62rebel
    i wish i knew, brother; finding the right combination of pulley, balancer, and alternator brackets that get the belt in anything RESEMBLING a single plane is a *****. at one time i even fabricated spacers to fit between the water pump pulley and the flange to bring it out even. Ford did NOT make all things equal on SB's. i spent two days scrounging the local pic-n-pull for pulleys the last time i swapped a V8 into my Falcon.
  3. easttown
    easttown
    how about these pulleys?
    397-m-8509-dm...ford racing...wonder if the would work for me?
  4. 65COMET
    65COMET
    I used the March pulley set that has just the alternator,crank and water pump pulleys.Sorry,I don't remember the part number,never could find a stock single pulley set up. ROY.
  5. junkyardjeff
    junkyardjeff
    Try to find a mid 70s truck without power steering and you will get the pulleys you need,they are kind of hard to find but they are out there as I found a few sets down through the years. I only found one set on a car and it was a 70 torino but the rest were trucks and had a 69 van with a 302 without p/s years ago.
  6. Hot Turkey
    Hot Turkey
    I had to cut one off, works great.
  7. edseldude
    edseldude
    from bedford va
    Junkyardjeff is correct. I've been fooling with small block fords for years. Unless you're lucky enough to find a 1969-70-71 ford car with no power steerting you're stuck with looking for a mid to early 70's ford truck. I 've used pulleys from a 302 as they are the same. They maybe different diamaters but shouldnt matter on a 351. Of course March makes a set as does Ford Motorsport if you want aluminum. Happy hunting!
