Boat motor mounts for your hot rod?...
Discussion in 'The Hokey Ass Message Board' started by 3wLarry, Mar 14, 2011.
  1. 3wLarry
    3wLarry
    from Owasso, Ok
    Came across this yesterday. I went to buy some camel hump heads for cheap that I saw on craigs list. When I got there the guy was removing them from a sbc that came out of a wooden boat. This cast front motor mount was still hanging on it.
    What was cool about it was that it allowed you to run a stock fuel pump unlike a regular hurst saddle mount.
    I paid $20 for it.
    I don't know what type wooden boat it came from but the motor was a '66 283. Start checking out the boatyards...
    kidcampbell71 likes this.
  2. Butcher's Shop Customs
    from Paducah KY
    Looks like the mounts on the 283 out of my grandpa's Chris Craft. And similar to the mount we used to put a SBC in my brother's F-1. Just built it to hit the factory mounts on the frame from the flatty.
  3. MeanGene427
    MeanGene427
    from Napa
    The nice ones are for V-drives, nice and strong, as as the engine was out in the open, were designed with appearance in mind, usually nice castings. I thought about using a front one on the Falcon, but the car sits too low and would have had to cut it up too much. One thing I was told to resist is the temptation to try and use one of the cam drives through the front cover w/ water pump, as the pumps aren't very durable and are quite high maintenance. Do a search on ebay and there's usually a few mounts on there
  4. SquashThatFly
    SquashThatFly
    Buddy of mine had this holding a big block in his '36 Chevy Pickup
  5. There is one for a flathead Ford on eBay right now. My '64 Chris Craft Supersport had a great small block chevy in it (327 with 4 barrel) ran great, excellent craftsmanship on the installation of a V-8 in a wood boat.
  6. 34ratpickup
    34ratpickup
    from Orange, CA
    I used to own a 17' bahner jet with a 468 chevy in it. Had similar mounts in it. I think it would be
  7. MeanGene427
    MeanGene427
    from Napa
    Yep, just put a little plate over that hole at the center of the cam so you won't get tempted to use a boat pump. They look great, don't they? That's similar to the FE one I wanted to use in the falcon
  8. thaugen
    thaugen
    I think these are for a boat, don't know anything about them, info appreciated.
  9. REJ
    REJ
    from FLA
    I run one similiar to this on my HA/GR.
    Got two of them out of a boat that had a slant six in it, put one on my car and one on my sons.
    They were not cast, but fabricated out of 1/4" plate, they work great.
    Robert
