Hot Rods Question: 1931 Ford Model A Roadster (westcott body, 4cyl)
Discussion in 'The Hokey Ass Message Board' started by BigPeter, Mar 16, 2011.
  1. BigPeter
    BigPeter
    from Tucson
    I am considering purchasing my first hot rod:
    ***led as a 31 ford. Current plates
    Wescott Fibergl***
    Ford Pinto 4 cyl / Auto trans
    Ford 8 inch rear / drum brakes
    Custom ch***is on Model A Frame
    dropped front axle/disk brakes
    Paint is a 20 footer
    interior / top are good / excellent
    Car is well serviced
    Drives as expected.
    What is this car worth?
  2. AJofHollywood
    AJofHollywood
    Is this considered a hot rod?
  3. BigPeter
    BigPeter
    from Tucson
    How would you label it?
  4. Kinky6
    Kinky6
    It could be a bit hotter. At least its not a Shay. :rolleyes:
    Later, *****6 :cool:
  5. casper
    casper
    It's a really nice looking car, the fact that it is fibergl*** and Pinto powered will hurt the resale. I would say that car would sell for around $7,500. Good luck !!!
  6. BigPeter
    BigPeter
    from Tucson
    How about luke-warm rod? :)
  7. AJofHollywood
    AJofHollywood
    If you are in love with it and think you'd enjoy driving it, have at it! But if you think it's great a "collector car", think again. Any amount of money you spend on it, like repainting it, will not increase it's value like it would on an original car.
  8. AnimalAin
    AnimalAin
    If you have a vision for how you want it to come out, and how you want to use it, go for it. As mentioned above, it isn't inherently valuable, but seems to be a pretty neat little car. There are certainly enough positive elements there to make it a starting point, but think of it as an adventure, not an investment.
  9. BigPeter
    BigPeter
    from Tucson
    Actually, its pretty much meets my needs/expectations. I don't mind the 4cyl. It looks and performs as I want, and I'll enjoy it as a piece of transportation as well as a conversation piece.
    From my inspection of the car it shows "pride of ownership" by the existing owner so I'm confident I'm not buying a money pit.
    The goal of my question was simply to make sure I don't overspend.
  10. BigPeter (bragging?)is the webmaster at The Antique Car Club of America. I suspect he knows it is not a collector car or an investment. 58Mustang
  11. BigPeter
    BigPeter
    from Tucson
    Carl,
    My name is Peter, I'm 6ft3in.... argo: BigPeter :)
    And your observation is correct. :))
  12. rusty bill
    rusty bill
    Buy it and enjoy it!
  13. My geuss would be around 12 grand. If it makes you happy thats all that matters. To make it more hotroddy it could be lowered and loose the spare tire. If you need a label I would call it a fibregl*** resto rod, but fun does not need a label.
  14. rottenleonard
    rottenleonard
    You can get plenty of "hot" out of a 2.3 L ford, There are some trick stuff available due to their use in stock cars and other racing venues.
  15. cvstl
    cvstl
    from StL MO
    It would make a great daily driver. No worries about where you leave it, or somebody wiping out your old sheet metal, and should be pretty economical.
    If its a pretty solid car that you can use, I'd decide its value based on how I was going to use it. You can probably get good reliable transportation in that shape for $3-4k if you look around a little and aren't too picky. But the fun and uniqueness are also of value. I'd probably pay $6k - 8k if I lived in a place that I could uses a roadster for daily transportation. I realize that somebody probably has/had waaaay more than that in it, but that's what I'd pay.
  16. Pintos can be HOT! Lots of speed equipment out there.
  17. skirtless33
    skirtless33
    A Shay car will sell from $9000. to $12000 so I think this would sell for more that a Shay. If nobody knew it had Pinto looks like a nice rod.
