New Daily Driver... Another Fridge Cab
Discussion in 'The Hokey Ass Message Board' started by bloodyknucklehill, Mar 15, 2011.
  1. Picked this up today.. Gonna be my daily.. I'm really excited about it but it has a few bugs to work out first..
    It's a 59 Custom Cab with a 390 and a C6..
  2. TinShed
    TinShed
    Nice, I picked up a 57 about 2 weeks ago to do the same. Not as nice as yours but it will be a cool driver when I get the bugs worked out and the snow melts.
  3. 53olds
    53olds
    Awesome man, glad you went through with this. Last time we talked you sounded un-sure if you were getting this. :) cool!
  4. krackerjack88
    krackerjack88
    from Fresno,Ca
    3 Thumbs up! I just got rid of one. Had a 351C and a C6. I love those trucks and will be looking for another one soon. Great motor/****** combo.
  5. That will make a great driver!
  6. low-n-slo54
    low-n-slo54
    very nice. I need a truck.
  7. Thanks all. One of the bugs is a heat soak problem with the starter I think.. It starts ok when its cold but I stopped to get gas yesterday and went to leave and it wouldn't start. I ordered some heat wrapping for the starter, any one got any ideas?
  8. rustydusty
    rustydusty
    Nice truck!
    Had the same problem with a Chevy pick-up starter. Turned out to be a worn bushing! I would just replace the starter if it were mine.
  9. Thanks.. I might just do that if the heat shielding doesn't work.. Here's a couple interior shots.. It has all aftermarket gauges but i think I might put the stock ones from my 58 in there.
  10. H3O
    H3O
    looks good...now it just needs some bigger tires...those look too short in the back...check the solenoid...i had the same issue with mine and changed it out, haven't had an issue since...just a possibility...
  11. ironandsteele
    ironandsteele
    cool truck.
    just noticed your location, my grand parents live in Myrtle Creek. never been there, but they say they live "by the dairy queen" ?
  12. Yeah i thought the tires were a little short too.. They're 60's so it think i'll go with a 70 instead when i wear these down a bit.. Thanks for the tip on the solenoid too. I just happen to have a brand new one out in the shop..
  13. yeah you're not missing much.. That's why I live out of town :D
  14. redlinetoys
    redlinetoys
    from Midwest
    Fantastic looking truck. Congrats!
  15. Strange Agent
    Strange Agent
    Nice truck!
    X2 on the solenoid.
  16. Ok starting to think it's not the heat.. Problem only seems to happen when I get gas.. I just did a hot start on it and it fired up just fine... Now I'm really confused..
  17. krackerjack88
    krackerjack88
    from Fresno,Ca
    check all your grounds. I had a "starter" problem and one of my grounds was loose. Fixed it right up!
  18. I started a thread about the problem and someone suggested a dirty tank and that seems to make sense so I'll start there.. Here's an engine shot.. I still need to dig up more on the motor but the block code is C8ME, heads are C1AE, and Intake is C4SE, so i've got a '68 block, '61 heads, and a '64 Intake manifold other than that i'm still looking for info.. I'm gonna clean up those Mercury valve covers hopefully this weekend.
  19. another Pic and a funny story.. The truck didn't have seat belts when i got it so I went to the junk yard to hunt down some that would work.. The side trim on the hood is missing as you can tell as well.. So i find a suitable donor for the lap belts (a '70 F250) and i'm wrestling with the stuck bolts for about half an hour.. I pause to take a breather and shout obsceneties, then hang my head over the bed of the 80's ford right next to me.. When I look up I see a totally straight hood from a '59 sitting in the bed of it.. Guess whats on there and in very useable condition.. It was like a sign or something :)
  20. jrod60
    jrod60
    from Katy, TX
    I like your taste. :cool: I've got the rear trim rings and some peep mirrors on mine since this photo.
  21. R A Wrench
    R A Wrench
    from Denver, Co
    Great find, & on St. Pats day too. Would that be the luck of the Irish?
  22. ironandsteele
    ironandsteele
    awesome luck. i love finds like that. did you ever get those bolts you were cussing at unstuck?
  23. Yeah I got the *******s out finally.. So now I have seat belts in there for me and my two boys..
  24. hasty
    hasty
    Thats a nice truck
  25. Thanks.. It definately needs a little work but it's a damn good start.. first off i need to take a pedal out.. Whoever converted it to a C6 left the clutch pedal in there so I have to drive it with with both of my feet on the right side of the steering column.. This weekend I'm gonna put the brake over where the clutch went and remove a pedal..
  26. Got the emblems cleaned up and on.. She got her first bath too!:D
  27. Hotrod1959
    Hotrod1959
    looks pretty straight!
