chevy car vs. truck rearend
Discussion in 'The Hokey Ass Message Board' started by TIMMY P, Mar 16, 2011.
  1. I couldnt find it in a search so does anyone know if a 51 Chevy car torque tube rear is the same as a 51 truck rear. I know the truck is 6 lug and the car is 5 but are the width and length of the torque tube the same.
    Thanks
  2. Curt B
    Curt B
    Gears are not interchangeable and you can confirm this from vendors who sell the 3:55 ring/pinion sets.
  3. SlowandLow51
    SlowandLow51
    You can use the rear axle in your truck but it is not a simple bolt in.Look in the tech tips on "The Stovebolt Page" for a how to on this swap.
  4. Lone Star Mopar
    Lone Star Mopar
    What are you trying to accomplish with the swap ?
  5. I have a truck with a three speed and the gears are real steep , the truck dont want to go much over 50. I have a complete setup out of a powerglide car so I just thought maybe they were the same dimensions so I could lust swap them out instead of buying new gears.
  6. blown240
    blown240
    from So-cal
    Patrick's Ring and Pinion has a 3.08 ge****t that will work in your truck rear end.
  7. Curt B
    Curt B
    Patrick's ge****ts for torque tube cars and trucks are 3:55 ratio and do the job at making it highway friendly. I had the same idea as you but the issue is length. If you truck was a 46 or older that powerglide rear would be useful and here's the tech tip:
    http://www.stovebolt.com/techtips/torque_tube_swap.htm
