Does it need a straight axle to be a Gasser?
Discussion in 'The Hokey Ass Message Board' started by 1927 Death Trap, Mar 15, 2011.
  1. hotroddon
    hotroddon
    Incorrect. The gas cl***es which were the A/Gas, B/Gas, AA/Gas etc were a set of rules (that did change over the years) that dealt with cars that were "Street Equipped" (lights etc.), full fendered cars, with a 10% engine set back allowed. The different cl***es dealt with a cubic inch per weight formula, with a factor for supercahrged. The rules relaxed some what over the years, originally they had to have full interiors and complete exhaust, but the basic premise of a recognizable street car remained. Near the end they were pretty much full blown race cars, but the basic rules remained.
    A/FX etc were the factory Altered Wheel base cl***es - the FX stood for Factory Experimental and they were more radical than G***ers (at least in theory)
    Altered were a step above both of these and were around before FX cars. Full blown race cars that could run with the Top Fuel cars of the early days. Wild to watch with big blown motors and short wheelbases.
    Pretty much all three cl***es were killed by the emerging Funny Cars, but they never "went with the flow and renamed itself" - they were very distinct cl***es running at the same time.
  2. hotroddon
    hotroddon
    So close - Chop Tops were allowed in the G***er cl***es. just not in the very beginning ;)
  3. havi
    havi
    I won't argue, and like I said, I wish someone could chart the whole thing out. But this pic has me wondering. EDIT: I've heard different things from different people, and just trying to sort it all out.
  4. hotroddon
    hotroddon
    What are you wondering? Looks like a D/Gas car to me. stock wheel base, radius'd wheel wells, Tear Drop hood scoop - pretty basic stuff, and a cool car.
  5. storm king
    storm king
    One of the main things that separated a g***er from an FX car or a modified production car as well, was that a g***er did not have to have the same type engine as the body make.
    Top chops were always allowed, as long as I've been racing (1963), and again MOST g***ers did not have straight axles, but most of the upper cl*** cars did, as they were mostly Willys, Anglias, etc.
    Tunnel Rams? By the time tunnel rams came out, the gas cl***es were just about gone, if not completely gone from the books.
    Who are these people who come up with these fanciful notions with no basis in fact?
  6. skywolf
    skywolf
    Some even had torsion bar front ends.
  7. willowbilly3
    willowbilly3
    from Sturgis
    Well said. I like the old g***ers, when they really were. The g***er fad look for street cars misses the target in about 95% of them, lameness at a high level IMHO.
  8. hotrod_32
    hotrod_32
    Hotroddon...perfectly stated.
  9. jersey greaser
    jersey greaser
    NO! i ran gas with one of my 57 chevy's, ball joint spacers, up lift shocks. soft front springs out of a 6 banger.
    it was all in the motor and suspension and what was done to it.
  10. Larry T
    Larry T
    You want it charted out? Here's the rules for different years in black and white.
    Larry T
    http://www.jalopyjournal.com/forum/showthread.php?t=334715
  11. Not all the REAL g***ers back in the day had straight axles. Alot of the tri5's had stock frt susp raised up alittle. Give it alittle nose high additude and call it a g***er. Dont do a DONK g***er.
  12. Wagonmaster2
    Wagonmaster2
    G***ers had engines set back up to a certain percentage of the wheelbase (10%?) Most g***ers of the day had the firewall cut out and the rear or the block was inside the car, covered by the new "boxed" firewall. Some had straight or tube axles without brakes, to reduce weight, and were high to improve weight transfer, as was previously said here. I remember the ones from the earlier days had Hurst shifters (handles turned backwards) so the driver could comfortably reach all the gears with the set back engine. Without the set back engine or straight axle, they could run Modified Production cl***es. A "true" g***er has a setback and I never saw one without radiused wheel wells. Spindle mounts??? Most g***er didn't have front brakes, but I don't recall any but the Pro owned blower motor cars havin' spindle mount wheels, AA/GS- BB/GS, etc. I like 'em ALL!!
  13. BigBlockBuck
    BigBlockBuck
    A lot of the real g***ers were't even lifted.
  14. Larry T
    Larry T
    G***ers needed 4 wheel brakes from at least 1964 (^^^^^see link to rules).
    Lots of G***ers in the 60's could have been turned into MP cars with a days work. A lot of them ran the engine in the stock location. On the tri 5 Chevys, the engine is as far to the rear as possible without a lot of firewall work. Many of the g***ers had injection and the MP cars carbs, until the developement work with tunnel rams surp***ed the hp available with injectors (probably late 60's).
    I've posted this car more times than I care to admit, but here's a typical lower cl*** g***er from the mid 60's.
    Larry T
  15. falcongeorge
    falcongeorge
    from BC
    Well, it probably didnt have the rear leafs mounted to the top of the rear axle either! Man, what are you trying to PULL??!!
  16. falcongeorge
    falcongeorge
    from BC
    Ooops. Somebody just fell into a sarchasm...
  17. 1971BB427
    1971BB427
    from Oregon
    Well you can pick 'em up in a g***er, but it only takes a few minutes and they want out! :)
  18. usmc50lx
    usmc50lx
    from St.Louis
    Don just for my knowledge since I wasn't around then correct me if i'm wrong and I probably am but wasn't '66 the first year tops could be chopped and why Ohio George did it on the willys for its last year before the Mustang changeover??
  19. Larry T
    Larry T
    I'm not Don, but the 64 Rulebook (link above) says "chopped, channeled or sectioned, but not more than 4 inches".
    Larry T
  20. Strange Agent
    Strange Agent
    It's just a car.
    Unless you're drag racing in a G***er cl***. :D
  21. Larry T
    Larry T
    I always thought that was what a G***er did. (G)
    Larry T
  22. Strange Agent
    Strange Agent
    I confess I didn't read the whole thread. The OP isn't going to race it?
  23. Larry T
    Larry T
    I don't think he really said if would be raced or not, but it looks like it's gonna be a street car.
    I'll admit I was being a little bit of a smart a**, but I do believe that if you're gonna call a car a g***er it should be able to p*** tech for the gas cl***es and nor completely fall on it's face if you went to the strip. But that's just me.
    I'll go sit in the corner now.
    Larry T
  24. havi
    havi
    And that's precisely why I want to get everything right for my '62. Thanks for the link, Larry.
  25. lorodz
    lorodz
    here is mine with a arms and spacers
  26. Warpspeed
    Warpspeed
    O/k,
    straight axles
    front guards
    Jacked up both ends
    fenderwell headers
    tunnel ram
    roll bar
    big tach on the dash or hood
    Sounds like a Monster Truck to me. Bwahahahahaha.................
  27. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Must be the Fosters. Just say'n, one wise crack deserves another
  28. 61 chevy
    61 chevy
    i thought a g***er was a silent fart that you let go in a crowd, and then walk off.
  29. American Pie
    American Pie
    from Lemont IL
    Thanks for posting the link with the `64 rules Larry. Wish I could find my 1969 rule book.
    I certainly agree with you that a car should at least be able to make a decent p*** at the track based on the cl*** it should have run, and do it safely.
    If you want to see some pretty fast Pro Gas cars running this season, check out the NDRL Chapionship Series at Indy, Bowling Green KY, and Edgewater Sport Park In Cleves OH.
    http://www.nostalgiadragleague.com/default.html
    Pro Gas will run heads up indexes 8.0, 8.50, 9.0, 9.50. They will run handicapped aginst the next closest cl*** thereafter in eliminations till we have a winner.
    BTW... As I recall, the Altered Cl*** cars were allowed engine set back 25% and were named that because the bodies and ch***is were altered more than G***ers. NHRA forced a few G***ers to run Altered Cl*** when the racer would push the limits on body mods, i.e. altered or missing fenders, hood, too much chop. Also they could be open cars were the G***ers were exculsive to coupes and sedans.
    Modified Production was more of a stock type suspension and body cl*** (they may have allowed flaired rear wheel wells), I believe single quad only. It was a step above the Super Stock rules and allowed far more engine mods.
    Looking back, Modified Production may have been the precurser to Pro Stock, just as the Supercharged G***er lead to Blown F/X cars, which lead to Funny Cars.
    Hope to see you all out there this season,
    Dave
    American Pie`37 Chevy G***er
  30. Sonny48
    Sonny48
    from Mo.
    When I was a kid we would take a 55 chevy and put an econoline front axle turned upside down in it and then reversed the rear shackles. We didn't call it a g***er...we just called it cool. Love that nose bleed look.
