ifs kit or subframe
Discussion in 'The Hokey Ass Message Board' started by awin4sin, Mar 18, 2011.
  1. awin4sin
    awin4sin
    from las vegas
    hey all , i am about to start a project its a 51 chevy i want ifs. can anyone tell me the pros and cons of say a kit from fatman and a nova 2 subframe or camaro? thanks
  2. awin4sin
    awin4sin
    from las vegas
    i meant 51 chevy deluxe coup
  3. 32fordroadster
    32fordroadster
    from Wisconsin
    The kits are expensive, but all the engineering is already done for you. I have used IFS kits in two projects and it is still alot of work but nothing like trying to graft in a subframe. It's a personal choice thing. Either way you get to be out in the garage getting your hands dirty!:)
  4. 49ratfink
    49ratfink
    Camaro clips are for cheap *******s and hacks.
  5. gwarren007
    gwarren007
    You can also grab a IFS from a 75-90 Jaguar with R&P steering for little $$, weld it in.
  6. Hnstray
    Hnstray
    from Quincy, IL
    A bolt in kit from TCI or Ch***is Engineering is the easiest, fastest, and likely most satisfacory alternative to "clipping it with a Nova/Camaro subframe. Those are often "cheap" and the results often are substandard. Now, before all you guys want to flame me by saying HOW GREAT your Nova/Camaro sub frame works......I have this to say......YOURS may be one of the exceptional few, or perhaps you just don't know the difference.
    BTW, there is nothing wrong with Fatman products, I have used a few and think they are one of the best in materials on the market. But for the '49/'54 Chevs that have a bolt in front crossmember from new, removing it and bolting in a new aftermarket unit just couldn't get any easier. Unlike most other cars of the era, the Chev frame rails are flat and straight and lend themselves to this changeover.
    Ray
  7. davidbistolas
    davidbistolas
    I have a CE crossmember in mine, it went in real easy. Like in a weekend, including beer runs. I ordered them with the mounts too.
    I'm not trying to be a *****, but you realize that your '51 chevy HAS an IFS, right? Used on the C1 corvettes too. Disk Brake kits available, and if you want to lower it you can cut the coils- but the ride will suffer.
  8. theHIGHLANDER
    theHIGHLANDER
    For the way the majority of them are installed, I'd be pretty close to the same opinion. I have seen a few that were exceptional and worked really well, similar to hnstray's opinion. Now you say "51 Chevy"...pick up? Sedan? What is it? The other popular mod if it's a truck is the S-10 conversion, which I dislike in so many ways, but it's effective and has ZERO traditional feel or flavor. I investigated using a tri-5 (55-57 Chevy p***enger car) front frame section in an AD truck. It wasn't looking too bad but I s****ped the idea when I sold the donor project car. The modern IFS "bolt in" stuff has come a long way from it's humble bracket racer beginnings. In the end it's where your budget takes you. Many an early rodder would use a complete frame and suspension for their projects. The Car Craft "Dream Truck" sat on a mid 50s Olds frame and running gear. My dear departed Dad dropped a 49 Ford pick up on an Olds 88 frame and running gear. Even if it's a car, not a truck, the same philosophy would apply but thorough and disciplined fab skills would be required.
  9. skidsteer
    skidsteer
    Main differences are how much $$$ you want to spend, and whether you think you may want to upgrade components in the future. Junk yards stil have lots of Novas.
  10. davidbistolas
    davidbistolas
    I'd say it's a fleetline or styleline delux. he says it's a coup (sic), not a truck...
  11. davidbistolas
    davidbistolas
    There's one side that I don't see here- clipping the car would mean that you need to figure out , design and fabricate brackets and such for fenders, bumpers, splashpan and the rad.
    With the MII crossmember route, you don't need to worry about that. (I didn't even take my fenders off when I did mine... but you would probably wanna do that for yours.
  12. seventhirteen
    seventhirteen
    from dago, ca
    i agree, luckily my wife likes cheap *******s and hacks and has loved driving her 50 mercury for the past 12 years
    for me personally, I liked using the front clip, motor, ****** and rearend out of a 78 camaro that just happened to be a buddies first car we used to drive to high school together.
    that said if you have the money the kits are great
  13. gimpyshotrods
    gimpyshotrods
    I will ask the same question I ask everyone who is attempting to replace IFS with IFS. What is wrong with the suspension that is in there?
    Is there a reason you want to do this? It is a ton of work to make a 60-year-old car handle like a 35-year-old car.
  14. 53sled
    53sled
    from KCMO
    My car definitely outperforms anything detroit had in 1953. It was less work than a clip and less cost than a kit.
  15. brigrat
    brigrat
    from Wa.St.
    Close to 10K post or not that is simply ignorant, naturally with all do respect!
    I have seen just as many "kits" installed by rich hacks or shops that shouldn't be doing that kind of work.......................
  16. gsport
    gsport
    i'd go with a MII.. i put one in mine last year and it was an easy bolt in. i used a ch***is engineering cross member with SBC mounts already welded in.. my car is a project and i don't have a need to be in a hurry so it's just a work in progress type of vehicle...
  17. Bob Abrew
    Bob Abrew
    ch***is engineering is a very good bolt in kit. Have one in my 52 bel air. I was told the frames in these early chevys is very weak, and do not take to welding to them. They tend to crack.
  18. hotroddon
    hotroddon
    and yet you don't say what your car has .....:confused:
  19. rusty1
    rusty1
    ...guess I'm a cheap hack!
    ...you better go with Ch***is Engineering bolt in if you don't wanna be one too!
    ...BTW, here's a 49 Fleetline I put a 72 Nova clip under, worked out great.
  20. George/Maine
    George/Maine
    I put a 77 camaro in my 52 hardtop,the tires rub the fender a little when turning
    shape.I think its a good soild front end handles like a sports car.Had a 350/350 with a 56 chevy rear got about 18 mile to gallon.Hard to mount bumber some good ideas here on this site.The nova would be better being rear steer.I paid $25 in 1999 for the clip.Today the mustang kits are better and i,d go that way today.
    I think the bolton one would be quick and get it done.
  21. seventhirteen
    seventhirteen
    from dago, ca
    when i got the 50 merc it had no front or rear suspension and the running camaro cost me $200, so at the time it was a no brainer
    i'd say there's a pretty big difference in a camaro clip and original 50 front end, power steering and disc brakes aren't cheap to add to original gear, parts for a 78 camaro are cheap and plentiful
  22. rcoffey
    rcoffey
    If you look there is a thread on this subject.there are lots of points of view and the guy shows how he did it.lots of good pics.I think im going to clip one of my 55 internationals.Its a week end of work and a 200.00 sub is lots cheeper than 2500.00 for stuff you buy from a catalog.just my .02
  23. bobby_Socks
    bobby_Socks
    from ǑǃƕǑ
    If you have the ability to install a clip from another vehicle and just want to know the pros or cons I would look at what the options are for the after market independent front end setups for your 51 Chevy like track width, brake options,A-arms,shocks, air bags and coil overs.
    Then I would look at what a clip is going to cost and if the front end needs to be rebuilt or parts need to be replaced that could make up your mind for you.
    I think that I just talked myself into buying a new independent front suspension and I don't even have a project to put it under !
  24. gsport
    gsport
    here's a list of front and rear ends, listing widths, weights, etc.... near the bottom for front ends used in clipping a car..
    The first gen camaro is slightly narrower than the second gen (70 - 82). First gen is 60 on the rear and approx. 60 1/2 on the front, which is almost exactly the same as your 50. This measurement is mounting surface to mounting surface (outside hub). The second gen is 61 1/2 on the front and 60 1/2 on the rear, mounting surface to mounting surface. Scroll down near the bottom of the info below and you'll find some clip measurements.
    Original Vehicles
    Rear Suspension Width (Flange to Flange)
    Year
    Cl***ic Vehicles
    Width
    26-39
    Plymouth-Dodge car/pick up
    56-58"
    40-52
    Plymouth-Dodge car
    60-62"
    26-39
    Chrysler/DeSoto Car
    60"
    Most Early
    Mopar's
    56-62"
    25-39
    Chevy Car
    56-58"
    26-46
    Chevy Truck
    56-58"
    40-48
    Chevy Car
    58-60"
    49-54
    Chevy Car
    58-60"
    47-54 & 55 1st Series
    Chevy Truck
    60-62"
    Most Early
    Buick,Olds, Pontiac
    58-61"
    28-31
    Ford Car/Pickup
    57 1/2"
    32 & 33-34
    Ford Car/Pickup
    56 1/2"
    35-48
    Ford Car
    57-60"
    35-41
    Ford Pickup
    56-60"
    49-58
    Ford Car
    57-58"
    49-56
    Mercury
    57-58"
    49-51
    Mercury
    61"
    64
    Falcon
    58"
    67
    Cougar
    60"
    55-59
    Chevy Pickup
    62"
    Donor Vehicles Front and Rear
    Year
    Cl***ic Vehicles
    Width Front
    Width Rear
    74-79
    Ford Mustang II/Pinto & Mercury Capri/Bobcat
    55 ½"
    55 ½"
    71-77
    Ford Maverick with 8" axle
    56 ½"
    75-80
    Ford Granada with 8" axle
    57 ½"
    64-66
    Mustang
    57"
    67-71
    Mustang
    59"
    72-73
    Mustang
    60"
    67-69 , & 60"
    Camaro
    60"
    64-67
    Chevelle
    60"
    55-64
    Chevy car
    60"
    65-67
    Nova
    58"
    68-72
    Nova
    60"
    60"
    78 & up
    Monte Carlo, Regal, etc. with 10 bolt axle
    58"
    58"
    68-72
    Chevelle with 10 bolt axle
    61 ½"
    89
    Trans AM (Disc brake)
    62"
    76-80
    Camaro/Firebird
    61 ½"
    60 ½"
    68-83
    Corvette
    58 ½"
    59 ½"
    84-95
    Corvette
    59 ½"
    60 ½"
    Early 70's
    "A" body (Dart/Duster) with V8&3/4 axle
    58"
    "E" Body (Cuda) with V8&3/4 axle
    58"
    Dodge Dart
    59"
    55 ½"
    Plymouth Volare & Dodge Aspen
    61"
    60 ½"
    71
    Blazer (6 lug)
    63 ¾"
    75-78
    Granada 9"
    (43" perch to perch)
    52 ¼"
    75-78
    Maverick 9"
    56 ¼"
    81-87
    Olds Cutl***
    58 ½"
    FRONT SUSPENSION INFORMATION
    Track Width of Popular Donor Car Clips
    Manufacture
    Model
    Years
    Track Front/Rear
    Curb Weight
    Chevrolet
    Nova
    68-74
    59.8-59.6
    3,770
    Buick
    Apollo
    68-74
    59.1-58.8
    3760
    Pontiac
    GTO
    68-74
    59.9-59.6
    3880
    Chevrolet
    Corvette
    68-83
    58.7-59.5
    3655
    84-95
    59.6-60.4
    3890
    Chevrolet
    Camaro (Z28)
    76-80
    61.3-60.5
    3820
    Pontiac
    Firebird (TA)
    76-80
    61.3-60.5
    3900
    Ford
    Mustang II
    74-79
    55.6-55.8
    3305
    Pinto
    74-79
    55.6-55.8
    3305
    Mercury
    Capri
    74-79
    55.6-55.8
    3305
    Bobcat
    74-79
    55.6-55.8
    3305
    Chevrolet
    Monte Carlo
    78-86
    58.5-58.8
    3235
    Buick
    Century
    78-86
    59.0-58.8
    3700
    Pontiac
    Grand Prix
    78-86
    58.9-59.0
    3735
    Plymouth
    Volare
    75-79
    61.0-60.5
    3395
    Dodge
    Aspen
    75-79
    61.0-60.5
    3395
    Dodge
    Dart
    76
    59.2-55.6
    3600
  25. Rocky
    Rocky
    Classified Editor
    The Chevys in the early 50s had a "top-hat" frame that was basically sheetmetal welded to a stouter steel base...not a good candidate for a clip job but with their straight-rail frames, they're great for a mustang II front. Several people have already named Ch***is Engineeering and a few other companies that make a good Mustang II crossmember.
    It's true, the original suspension can be rebuilt and re-used ok...kits are available for disc brakes for the old chevy spindles.
    Last one I built I used the original suspension, '54 steering and brakes with cut coils and a 1.25" stabilizer bar from a Trans-am. Next time I'll go with an aftermarket Mustang II based setup with rack& pinion steering/disc brakes etc.
  26. ifs kits make for a cleaner build. ive seen clipped cars. and they look just like what it is. another frame hacked into a different frame.
  27. todztoyz
    todztoyz
    I recently "bolted" a CE kit on my 51. Went on with minimal problems. Hardest part is removing the stock rivets. Seems alot easier than makin all new mounts for everything up front! I'll be doin the same to the rear if I ever get it back from the body shop! Good luck.
  28. artomotive
    artomotive
    from olean ny
    Im looking to put a 2nd gen stub on a 53 chevy truck any ideas.
  29. AA/Fuel34fordpu
    AA/Fuel34fordpu
    Do a search on here the bolt in IFS from CE is the easyest to do. Its not cheap but if falls right in to place with no BS!...
  30. rockin rebel
    rockin rebel
    I have been looking here for a long time and for several different cars.. AND I CAN NOT BELIEVE ALL THE NEGATIVE ****, THAT COMES OUT OF THE MOUTH OF 49RATFINK.....CHILL BUDDY.!! you never say anything nice..??...wtf ??
