8ba to eab strato star engine swap?
Discussion in 'The Hokey Ass Message Board' started by True till Death, Mar 17, 2011.
  1. True till Death
    True till Death
    Looking for info on swapping an EAB strato star engine into my 51 shoebox.
    From what I have seen online the only areas of concern about the swap maybe mating it up with the 51 tranny, weight and engine mounts, and the oil pan clearance
    Can anyone elaborate? Or tell me if this holds true and what I may need to watch out for?
  2. V8 Bob
    V8 Bob
    I'm not familiar with the term "strato star", but the EAB flathead engine that came in '52-'53 Ford cars is basically the same as all '49-'53 flatheads, except for the heads. The blocks are the same, as well '51-'53 water pumps, but the center hump oil pans are not, and am pretty sure the '51 pan has to be used for crossmember/steering clearance. Simply use the '51 full stamped bell housing, flywheel, clutch, exhaust, etc, and you're done.
  3. scrubba
    scrubba
    I have to agree with Bob here . The oil pan can swap , so can a transmission . scrubba
  4. Dale Fairfax
    Dale Fairfax
    What is prompting you to make this swap? Is the existing engine worn out/not running? Are you looking for some performance gain? If the latter, there was only a 10 H.P. (advertised) difference-probably not worth the effort to change it. Swap the cylinder heads and achieve the same "gain".
  5. arkiehotrods
    arkiehotrods
  6. True till Death
    True till Death
    Dale Fairfax after much debate and trying to figure out what direction I was going to take with my build. I figured it would be best to get the car running and enjoy it for the summer vs. a long and pricey tear down a rebuild of the car and original 8ba engine, it would be better to swap a known good and running engine. Also being an eab I can steal the 4" merc crank and heads out of it come winter and have a stroker build for the 8ba.
  7. V8 Bob
    V8 Bob
    EAB has a Ford 3 3/4" stroke, EAC has a '52-'53 Merc 4" stroke. You need to learn more about what you really have.
  8. True till Death
    True till Death
    Sorry v8 bob, i got my info from vanpeltsales.com and must have read the spec sheet wrong, regardless it's still a running flathead. which i dont have with my 8ba. And i would have figured it out once i tore it down , i can still gets the head off it as well. from what i understand there the best flowing of stock flatheads. is that correct v8 bob or am i mistaken with that fact aswell?. thanks for the correction and information though
  9. V8 Bob
    V8 Bob
    The EAB heads have the highest compression of any late stock heads.
    No need to be sorry. I understand how some of the flathead info can be a little confusing to someone new to these engines. Didn't mean to come across gruff.
  10. Mike51Merc
    Mike51Merc
    My understanding is that the EAB/EAC series also have the best OEM camshaft.
