C4 Transmission fittings
Discussion in 'The Hokey Ass Message Board' started by rebelrat, Mar 18, 2011.
  1. rebelrat
    rebelrat
    Any one know were I can get the adapter fittings to fit the line in and out on a c4 I want to replace the fittings on the case to hook up 6an lines to my cooler. I cannot find any info on the thread and size of the hole,s on the case. Thank's Guy's
  2. rebelrat
    rebelrat
  3. potshot
    potshot
    from MT
    I'm pretty sure the case is 1/8 npt. Try a 1/8 pipe ****** in the hole and see how it fits.
  4. rebelrat
    rebelrat
  5. gimpyshotrods
    gimpyshotrods
    Your answer if on the page you posted. It says there that they are 1/8"-27 NPS, or National Pipe Straight threads. This is opposed to 1/8"-27 NPT, or National Pipe Taper threads.
    You can either get a 1/8"-27 straight die and modify fittings as they did on that site, or tap the case 1/8"-27 NPT. Of course, don't tap the case unless it is apart.
    If you run NPS fittings, they will need an o-ring or a copper crush washer to seal them.
    Of course, the guy on the site you posted is selling them for $16 (+$5 s/h), for the pair.
    You could just toss him a bone. He's just 220 miles from you, too. You could have them in a day.
