My freshly rebuilt '42 Merc. <iframe ***le="YouTube video player" src="http://www.youtube.com/embed/R1bmVJJeeAQ" allowfullscreen="" width="640" frameborder="0" height="390"></iframe> Bob
Schneider cam. Here's the details: 1942 Mercury 239, bored .060" over (249 cu. in.), Stcok 29A heads, Schneider 260º duration / .355" lift cam, Johnson type hollow adjustable lifter, Lincoln Zephyr valve springs, '49-'53 Mercury intake with Rochester 2GC carb, full flow oil filtration modification with spin on filter, and PCV system.
Thanks! Yeah, I feel guilty about the Rochester. They came on small block Chevys, and everybody's got one of those. However, the Rochester is a great carb -- traditional, cheap, easy to tune, doesn't leak, and bolts right up to the Merc intake. Bob
See post #6. Looks like you got a good start. I've built lots of engines in the past 45 years, but the flathead was a new experience, and none have given me a woodie on start up like this one has. It really makes you experience the essence of old time hot rods like nothing else. Good luck on yours -- Bob
Don't feel guilty about the Rochester. Like was stated it's one of the finest simplest, most versatile carbs ever built. They come from the factory (in different cfm ratings) on just about every GM product ever built at one time or another. I've used them on BBC's (in multiple arrangements) Chrysler and Ford engines and VW's. I held the hill climb record for 1200 and 1600 cc Vw's with them adapted to single port VW heads for over 3 years at the Ogema Sport and Trail hill climbs in northern Michigan with 2 different sized Rochesters competing against Webers and fuel injected rail buggies. A small one on a 283 will net you over 20 mpg in a sanely driven A body GM offering. Frank
The one on my flattie began it's career on a '66 Buick 340. Small base with the 1 7/16" throttle bores. Bolts right on the late Merc intake. Bob
love the video. inspires me to find a better job to make the money to rebuild my 21 stud. is that an alternator i see on there? if so, what kind from what motor? also, what fan are you using to cool it? thanks for the info. great motor!
Yes, it's an alternator. It's one of the small Denso style such as used on Toyota fork lifts. I wanted to use a mechanical fan. Fan height with a central mounted alt/gen can be a problem in an AV8, so I built a combination fan carrier and alternator bracket. That lets me get the fan down much lower than if mounted to the alt/gen. If you look closely, you can see that there's no flange on the fan shaft. I'm not going to cut the shaft to final length and weld the flange on until the engine and radiator are mounted in the ch***is. Bob
