disk brakes for a 36 ford pick up
Discussion in 'The Hokey Ass Message Board' started by 55vicky, Mar 21, 2011.
  1. 55vicky
    55vicky
    hi there so i traded my 55 ford Victoria straight across for a 1936 ford truck im now in the process of wanting disk brake on the front but i dont want a mustang II front end,(plus im on a buget) now ive look around and i see that speedway sales a 37-48 disk brake kit but im not sure if it will fit my truck, also is there any other option that i could go with that anyone know about. thanks .
  2. danz35
    danz35
    don't remember for sure where the kit came from,maybe Ch***is Eng. but I had 1972 Camaro discs on my 35 pickup-on the original axle/spindles worked great and not $$$$...Dan
  3. Larry W
    Larry W
    from kansas
    Speedway works, also ECI. Thats what I used on my 35 sedan. Just make sure you use wheels that will clear your calipers. danz35 is correct
  4. Larry W
    Larry W
    from kansas
    Used the same on my roadster
  5. 55vicky
    55vicky
    thanks for the help guys i really appreciated, i don't want to be picky but do you have any more pictures of that set up Larry.thanks.
  6. willowbilly3
    willowbilly3
    from Sturgis
    A freind of mine built his own. He used the speedway weld on brackets for a rear end and modified then to fit. S10 calipers and rotors. He had to machine a spacer for the spindle and got to the bearing store for bearings.
  7. 31Apickup
    31Apickup
    The commercially available disc brake kits are for 1937 to 1948 spindles. I haven't seen a kit for the 36 and older spindles. The picture in the earlier reply of the dic brake install are on 1937-1941 spindles. You would have to change to the later spindles, or fabricate your own setup.
  8. pasadenahotrod
    pasadenahotrod
    from Texas
    If your car has juice brakes now it likely has had a spindle change to 37-41 round flange or 42-48 square flange Ford spindles. The round flange ones will be marked 78- and the square ones 21A-.
  9. andres vasquez
    andres vasquez
    Hey there vicky55 my name is Andy. I read your post and wanted to let you know I have a set of disc brakes I was gonna use for my 36 pickup. I have the complete setup that bolts onto a straight axle. They came on a lowered axle I bought for my pickup. Includes spindles, calipers, rotors, and brake lines. 1 brake pad is missing, was looking to get $225 for the setup.
  10. 117harv
    117harv
    The smaller rotors usually only come in Chevy and small Ford five lug pattern. If you want to run the large 5 on 5 1/2" pattern wheels you will have to find an oem rotor. If you want to run the 36-39 wide 5 wheels you are sol.
  11. Bruce Lancaster
    Bruce Lancaster
    There is or was a Ford pattern 5 1/2" kit...I think both P7J and Speedway. Do not know if it still exists or if it was based on some stock (Ford pickup??) disk. Anyone current on that??
  12. forty1fordpickup
    forty1fordpickup
    I have the Speedway kit on my 41 pickup. It uses the mid '70s F100-150 rotor and Full size mid 70s Chevy car calipers. You can download the kit manual from the Speedway site for the specifics. I am running the disks with the stock rears through a 70 C20 master cylinder. Very pleased with the brake performance.
  13. MATACONCEPTS
    MATACONCEPTS
    1940 ford drums is the way to go on that truck. Most here would agree. RIGHT Y'all???
  14. 40FordGuy
    40FordGuy
    Magnum Axel also has a good kit for this,....I believe you can get it from Speedway. Mine came from Sacramento Vintage Ford. 4TTRUK
