64 impala power steering
Discussion in 'The Hokey Ass Message Board' started by tony070804, Mar 22, 2011.
  1. tony070804
    tony070804
    Ive rebuilt the cylinder and control valve and replaced all the hoses on the power steering on my 64 impala wagon. now it works great other than if you let go of the wheel it turns to the right by itself! does anyone know whats going on?
  2. dlinden
    dlinden
    from Denver
    is it turning right, or is it pulling to the right? could be a gearbox issue or an alignment issue, depending on what its doing.
  3. brigrat
    brigrat
    from Wa.St.
    Have your front end aligned!
  4. tony070804
    tony070804
    not pulling to the right its turning to the right! it will do it sitting still!
  5. brigrat
    brigrat
    from Wa.St.
    I would say the power piston valve is not centering it's self, maybe bleed it?
  6. 48 Chubby
    48 Chubby
    Controll valve. Could be a stuck spool, or a dirty or improperly installed check valve.
    Take it back apart and look at the ***y manual closely. Been a long time but I remember that they are easy to get wrong.
  7. StanDaManTX
    StanDaManTX
    from The South
    power steering is finicky huh? We put the hoses to the control valve on backwards and the wheel took over turning left and right like the car was posessed haha. Buddy told me that would happen, but it was the first time I have ever seen it lol
  8. 325w
    325w
    Look for a chevy manual. There is a procedure to go thru to make the adjustment.
