Hemis with 6 Carb Pics, Please Help!!
Discussion in 'The Hokey Ass Message Board' started by luciomduran, Mar 22, 2011.
  1. luciomduran
    luciomduran
    I am looking for Pics of 6 carbs on top of a Hemi for a model I am building. Any help would be appreciated.
  2. luciomduran
    luciomduran
    Specifically, Strombergs.
  3. 554coupe
    554coupe
    from Australia
  4. 554coupe
    554coupe
    from Australia
  5. junkyardgenius
    junkyardgenius
    from Kernow
    here ya go
  6. luciomduran
    luciomduran
    No pics are showing up. I will try a different browser.
  7. luciomduran
    luciomduran
    Would the fuel lines come off of the drivers side of the carbs?
  8. 554coupe
    554coupe
    from Australia
  9. 554coupe
    554coupe
    from Australia
    I also have an 8 carb set up on a plastic hemi if you want a pic but they are 94's
  10. ZomBrian
    ZomBrian
    from in IN
  11. luciomduran
    luciomduran
    That thing is so sick. Perfect.
  12. luciomduran
    luciomduran
    This is what I am working on. I am trying to figure out on what side of the carb the fuel lines come out of and how they will go into the fire wall. Will it be one inlet with 6 fuel lines going into it or 2 with 3 going into each.
  13. olskool31coupe
    olskool31coupe
    from Midwest
    These are 94s on this Edelbrock log manifold. Sorry, don't have the fuel lines or linkage installed yet. Just mocked up.
  14. 554coupe
    554coupe
    from Australia
    as you look at the car the fuel line intake to the carb is on the right . you could plumb the fuel line for the left bank of carbs back to the centre & run them back to a six outlet fuel block on the fire wall ?
  15. luciomduran
    luciomduran
    That's what I thought but I just wanted to make sure before I start running them. THose little resin carbs are expensive for model parts, so I wanted to make it right the first time. Thanks Guys.
