Customs All EnfieldJoe wants for Christmas is a kustom Merc!
Discussion in 'The Hokey Ass Message Board' started by UnIOnViLLEHauNT, Dec 17, 2010.
  1. Progress looks great.
    I've got my plans for my floating grille, but I'm not going to decide until I've driven the car some and lived with it.
  2. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Sounds like a good plan. I read your grille thread in an attempt to get more ideas. Most likely won't do the DeSoto teeth grille.
  3. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Here is the latest pix of the ch***is. Just waiting for the SBF to be rebuilt and then I will install the motor/trans. Plumb up the fuel lines and then install the 51 body.
  4. rangeman
    rangeman
    from medford,or
    Looking good. If you use the original foot pedal and a new booster, will you be able to run the exhaust through the frame holes? I am currently at this point in a 51 merc build -350, 700r4, 9 inch- and wondering which brakes to use. Firewall chevy or the nicer original style. Current exhaust runs through the frame.
  5. HomemadeHardtop57
    HomemadeHardtop57
    I wish I had his wallet..ahah..Seriously though..great chop on that one..nice work
  6. RalphyBoy161
    RalphyBoy161
    Chris,your MAGIC with Mercs is Incredible.A master craftsman by far,Keep Rockin da'Torch ma'man!
    -RalphyBoy
  7. Smokey2
    Smokey2
    FUNNY! YOU would SAY Sick As A DOG!!
    Tha Merc LQQKS REallie Goood.....Good FLOW, And that's whata makes "tha Look".
    Swooop Look, And nothin' does it better than 49-51 Merc.........Nothin', Well Maybe '53
    Chebie? Or 40's Buick! I was Lucky when did my '49 Chop, was serv mgr at Linc-Merc Dlr., an found n.o.s. grille shell,...........way back in upstars loft!! Don't mean to rub it in!
    (Ha1).........Be diffferent on tha' GRILLE, But with Good taste!! You want peoples lookin' at the CAR!......Not just the grille, or taillites, or dash!!! EDSEL said it BEST!.....
    LESS, IS MORE! Sut-tle!
    Great Build........More Pictures, Thanks fer Listening. John.
    ____________________________________________________________________
    "A shot of Tequila!, and I fired Right UP!! Kool, Keep K, in Custom, I mean,
    KUSTOM......
  8. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Yes, I am using the original brake pedal and the stock location for the booster. The original location for the exhaust system was thru the p***enger side. To tun a dual exhaust the driver's side "X" must be cut.
    Since I am using a dual master cylinder with power booster, their is no room to run exhaust on the driver's side. My plan is to use oval shaped exhaust, but only a single using the p***enger side like the original exhaust system.
  9. hvychvy
    hvychvy
    Lookin great!!Can't wait for more updates.
  10. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Here are the latest pix of the body work.
  11. Nice are you doing the bodywork locally in GA?
  12. slddnmatt
    slddnmatt
    hey joe, we originally planned to run the exhaust to swing under the frame behind the A-arms and run it down each "tunnel" on either side by the rocker panels, then you don't have to worry about dodging anything.
  13. enfieldjoe
    enfieldjoe
    from Eustis, FL
    John: UnionVilleHaunt (Chris) is doing the chop and all the bodywork. He will also put the body in primer. Could not find a soul in the Savannah area to touch this project. I am very pleased with his work.
    The 51 should be down here in April. I will then install the body on the custom ch***is (built by Slddnmatt).
    Chris is also going to do my 50 Merc. That will go up North on the return trip (51 delivery).
  14. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Matt, my thoughts are well. Just challenged by how to exit the body from underneath that area without cutting a hole in the body. Thinking about oval shaped exahust pipe to make the exit. Any ideas?
  15. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Matt, did you mock up the SBF with any special headers using that exhaust routing method? I was just thinking about a set of shorty, block hugger type headers.
  16. Bad Bob
    Bad Bob
    from O.C. Baby
    Looking good guys! I like how the windows came out,with the slanted B-pilar.
  17. slddnmatt
    slddnmatt
    one of the other cars that i have at the shop just had some block hugger shory headers that are all over ebay that i used for a looksy, and then planned to run them towards the back putting a flange right before the rearend to be able drop the rearend if you need to, and the exhaust would dump out at a slight angle behind the rear tire. the exhaust would be hidden.
  18. I think thats a great idea Matt
  19. enfieldjoe
    enfieldjoe
    from Eustis, FL
    I will post pix when the exhaust is mocked up. Maybe a photoshop exercise on a ch***is side view pix to illustrate the exhaust system routing before the mockup will work also? I will have to see what I can do with photoshop. Either way, I will post some pix.
  20. enfieldjoe
    enfieldjoe
    from Eustis, FL
    photo.jpg Here are some of the latest pix. Body work is progressing.
  21. enfieldjoe
    enfieldjoe
    from Eustis, FL
    A possible grille solution.
  22. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Hood, possible grille, and rear view, body in-work.
  23. enfieldjoe
    enfieldjoe
    from Eustis, FL
    The 51 Merc is ready for a test fit of the gl***. Thanks Chris for a Job Well Done!
  24. Boys that is lookin GOOD!!!! Let me know when it rolls past Atlanta on the way home!!!
