Royal Purple or Amsoil ??
Discussion in 'The Hokey Ass Message Board' started by Rice n Beans Garage, Mar 22, 2011.
  1. Rice n Beans Garage
    Rice n Beans Garage
    Hello out there !!
    Anyone running Royal Purple or Amsoil oil in their rods or daily drivers ??
    Just want to get some Feedback
  2. 29AVEE8
    29AVEE8
  3. TwinTownTerror
    TwinTownTerror
    from Minnesota
    Brad Penn Oil only.
  4. Retro Jim
    Retro Jim
    I am going to be using Amsoil in my 55 Ford that I am building a 302 flat tap in . They have an oil with the zinc in it for flat tap engines .
    Royal Purple is also a great oil but I can't find the one with the zinc in it for my cam in my area . My Amsoil cost me $10 a qt and last 5000 miles or 1 year before changes . I also use K&N oil filters or Amsoil carried the good WIX filters too . There really isn't any better filters than those 2 around . But that's just my opinion and what I use and trust !
    Retro Jim
  5. Gman0046
    Gman0046
    Brad Penn plenty of zinc for $4.99 a quart. If cam manufacturers recommend it its good enough for me. Don't be snookered into believing all Royal Purple contains a high level of ZDDP. Its only some of the racing oil.
  6. manicmechanic
    manicmechanic
    I have Royal purple in all my cars. I even just replaced the oil in my air compressor with Royal Purple that is specifically designed for reciprocating air compressors. A great product, nothing but good things to say.
    <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p> </o:p>
    <o:p> </o:p>
    Nothing but problems with Amsoil. I lost two engines after 15k on Amsoil, and one transmission after 60k (4 speed granny gear). Back then I ran a fleet of 15 trucks, and was surprised at the number of failures by just changing the oil.
  7. drfreeze
    drfreeze
    i've been using Royal purple in my drag/street bike. i have about 1500 miles of 1/4 mile p***es on it and about 1000 miles of street riding i've been through the engine to check things out once and the inside looks better thank new ... not to mention the 6 hp extra on the dyno with just a oil change .....but as for daily driver i would use a good oil with zddp + filter and change often you shouldn't have a problem
  8. harley rider
    harley rider
    I use Amsoil in every thing .big block and small block chevy trucks ,harleys ,mowers, generator .if it has an engine it gets amsoil .yes it may cost a little more it is worth it . I run it in both of my trucks for over 6000 miles between changes.10,000 miles in wifes stratus . lasts longer runs cooler!!
  9. Left Turn
    Left Turn
    from Omaha, NE
    Brad Penn is what I use.
  10. 64gtoguy
    64gtoguy
    Royal Purple,,,,,,,,,, for 4 years in my 64 Goat, never a problem.
  11. 92GTA
    92GTA
    AMSoil is not as good as RP IMO. That being said, after 10 years of using RP it still leaves a build-up. Redline is all that I use now, has all of the zinc and phos you could need.
    BobIstheOilGuy.com
  12. Igosplut
    Igosplut
    Only some of the Amsoil has ZDDP in sufficient quan***y's. I have the list somewhere around. I use Amsoil in everything except the flat-tappet motors. Those I use Brad Penn.
  13. richie rebel
    richie rebel
    brad renn is the ****,only cost me 3.60 per. qt,when you buy it by the case hear in pa
  14. Jalopy Jim
    Jalopy Jim
    I use Amzoil in every thing I own. They do carry a flat tapper line of oil.
  15. Ole don
    Ole don
    Rotella T gets my vote. Its avaiable in 10W30 and 15W40 anywhere. It contains 1200 to 1300 PPM zinc. An article in Old Cars Weekly a while back said anything with over 1000 PPM zinc is good.
  16. JonF
    JonF
    Who is Brad Penn?
  17. Igosplut
    Igosplut
    BRAD PENN
  18. f100newb
    f100newb
    I am a HUGE RP fan. I use it in all my vehicles and have always liked it. They make a lot of claims and I can attest to them. I ran it in my Roush Mustang that was supercharged and had it dynoed when I first got it and after the I changed the oil with RP a few times we did a dyno day and I had it redynoed and saw 5 hp gain. No ****ting you. Only thing I did was change to RP after I got the car (second owner).
  19. dirty old man
    dirty old man
    Now just how do you know Amsoil was the problem on those engines and/or that trans? You don't suppose you could have ****ed up yourself do you?
    I started using Amsoil in 1974 when the first oil crisis popped up and I was commuting 35 miles each way to work, trying to increase gas mileage and it worked.
    Along the way since then I've used it in many vehicles, gaining many benefits from it's use. Liked it so well I became a dealer and sell it to a lot of people, who also like it.
    I ow use Amsoil in everything I own from my weedeater to my Silverado with the Duramax diesel. Once the rings are seated and the cam and lifters broken in, it will be in the SBC in the '31 "A" roadster I've almost finished. Amsoil doesn't rec. using their oil till then and I'm using Gibbs Racing Oil's break in oil till then because of solid lifter flat tappet high lift cam.
    Amazing how some folks want to blame anybody/anything else but themselves for their mistakes.
    Dave
  20. partsdawg
    partsdawg
    from Minnesota
    If amsoil was so great nobody would use anything else.
    I would never buy a product from someone who refuses to acknowledge that a oil product could be at fault and then states it has to be the users fault.
  21. slammed
    slammed
    Some of you take this WAY too personal. Someone disagrees w/ your favorite brand, you drop the F-bomb.
  22. JOECOOL
    JOECOOL
    If I'm not mistaken,and it would be the first time today, Brad Penn is the old Kendall,or new Kendall. A lot of the alcohol drag cars use it as It's supposed to be the thing for them. I don't think its available around here. I envy people who own engines tight enough to use synthetic oil in them. I put some in my pickup and it leaked like the Valdez.
  23. dirty old man
    dirty old man
    There's nothing wrong with the Amsoil, or any other reputable nationaL brand of oil for that matter, although some are better than others and my experience over the last 37 years of using and 10 years of selling Amsoil convinces me that it is a**** the best.
    In the case of the engines, he stated he had "rebuilt" them. I submit to you that not all "rebuilds" are created equal in parts, machine work, clearances, and above all, skill of the "rebuilder".
    Dave
  24. gasser300
    gasser300
    from Ft Worth
    Valvoline VR Racing has that there zinc stuff.
  25. bill wallace
    bill wallace
    'dirty old man" has it right any reputable brand oil is good. The SAE has data on oil testing. Everyone always thinks that the brand they use is the best & folks always have stories of this guy or that that had a engine fail because of the oil when you have no idea what really caused it.
  26. bill wallace
    bill wallace
    ''Dirty Old Man" has it right any reputable brand is ok.
  27. xhotrodder
    xhotrodder
    It has always amazed me how someone can state their opinion on here, and if it differs with someone elses, they run that person down and attack them verbally. Amazing.
  28. I went on the Amsoil site, checked out their info and decided to give it a try in one of my cars. I chose the high-zinc oil. It held oil pressure well and kept the parts inside super clean. I then started using it in my other car after the engine was broken in. I have a lot of $$ in the motors and have no intention of cutting corner$ on oil. So far I have no complaints.
  29. Chevy Gasser
    Chevy Gasser
    I run John Deere torque guard plus 50. It is basically Rotella T, plenty of zinc and turbo rated. A friend is in the oil packaging business and claims most oils are just repackaged. He is working on getting our car club a tour of a major oil testing laboratory that supplies most oil repackagers with their technical data. Brad Penn, isn't he the guy who starred in that ***anium Movie?
  30. stealthcruiser
    stealthcruiser
    Old Man Penn's youngest Boy....................:eek:.....:D
