Rear end dimensions, is there a comprehensive list anywhere?
Discussion in 'The Hokey Ass Message Board' started by Stevie Nash, Mar 23, 2011.
  1. Stevie Nash
    Stevie Nash
    So I've figured out that the existing rear end in my ride is too wide even when messing with backspacing. SO..... I'm going to try to find a rear end with the correct dimensions to fit my existing rim/tire combinations.
    I've done a search, but can't seem to find a thread with popular rear ends and hub to hub measurements. Anybody know of one out there? Bolt pattern would be useful too, I can run 4x1/2 or 4x3/4. Need late model also...
  2. scoop
    scoop
    Carnut.com has some.Go to car tech.
  3. Yes there's one, think its in the archives, had it book marked in my old computer before it crashed.
    It extremely helpfu
  4. rangeman
    rangeman
    from medford,or
  5. Stevie Nash
    Stevie Nash
  6. rodknocker
    rodknocker
  7. gwarren007
    gwarren007
    What WMS to WMS are you looking for?
  8. Stevie Nash
    Stevie Nash
    I need to find a rear end 61" from WMS to WMS, with 5 x 4 3/4 (GM)... and preferably lower gear ratio for highway driving (have 350 turbo trans)
  9. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Punch in 'Quick Performance" Sorry=no link:(
  10. ClayMart
    ClayMart
  11. gwarren007
    gwarren007
    60.5" chevy camaro/firebird 70-81 (8.5" RG) leaf spring
    60.5" camaro and firebird 82-92 (7.5/7.625 RG) coil spring
    60" S10 4X4 (7.625 and 8.5 rg)
    The camaro and firebirds will generally have 2.41-3.08 gear ratios for the V8's, the sixes usually have higher ratios 3.23-3.73
  12. atch
    atch
    there are several in here...
  13. xderelict
    xderelict
    64-69 1/2 ton 2wd chevy=60-61"
    64-67 Chevelle=62"
  14. toolman1967
    toolman1967
    I just went to CARNUT and found the spec page. Been on there hundreds of times and did not know that was there.
