Customs The f%&k you %$ hospitolized please send prayers (((My 54 CHEVY)))
Discussion in 'The Hokey Ass Message Board' started by Gambino_Kustoms, Mar 22, 2011.
  1. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    thats why i love ya bro you tell it like it is STUGOTS but you know me i gots to colpacate **** nothing easy is worth the troble ha ha ha
    yes you will
    not yet
    my thought exactly thanxs holmes
    i thought the same thing its a piece of mind groucho just like my frame all pinstriped no one ever sees it but i know its there hope you can make the sit down this year!
  2. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    here we go
    all right now
    wont ya listin
    <object style="height: 390px; width: 640px"><param name="movie" value="http://www.youtube.com/v/wAy9hKfsqYY?version=3"><param name="allowFullScreen" value="true"><param name="allowScriptAccess" value="always"><embed src="http://www.youtube.com/v/wAy9hKfsqYY?version=3" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="640" height="390"></object>
  3. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    thanxs
    yes we do and bad *** friends:D
    thank you vary much
    see ya there holmes
    thanxs
    thanxs grocho thats why they pay ya the big bucks
  4. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    bad news
    <object style="height: 390px; width: 640px"><param name="movie" value="http://www.youtube.com/v/6agBG3g2Vmk?version=3"><param name="allowFullScreen" value="true"><param name="allowScriptAccess" value="always"><embed src="http://www.youtube.com/v/6agBG3g2Vmk?version=3" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="640" height="390"></object>
    GAME OVER:(
  5. jlouie
    jlouie
    DAMN!! That close.
  6. Ahhh, sorry to hear, see ya in Austin.
  7. Ian Berky
    Ian Berky
    Nooooooooooo!!! Very sorry to hear Alex!:(
  8. My heart is breaking for you. Damn!
  9. styleline
    styleline
    from so-hol
    well alex that,s ****y to hear good luck to you man
  10. RUN IT! If it turns over (not frozen), run it. Change the oil after a few minutes and forget it. BUT, make sure you run a Zinc additive and Valvoline 20-50 RACING oil to protect the cam. I had a 454 that was so frozen from rust it took 3 days to free it up. It barely made enough compression to fart #1 cylinder to stab the distributor and it ran GREAT. It ran so good I put a performance cam in it 6 months later, ran it some more, sold it to a friend 10 yrs ago and it's still fine. You'd be shocked at some of the rusted **** I've got running over the yrs. I have a 37 Lasalle in my shop now that purrs. It sat with wet sanding water in the 3 cylinders with stuck valves and a piston that took WEEKS to unstick after THIRTY SEVEN yrs of sitting
  11. sodbuster
    sodbuster
    from Kansas
    Was the old motor that bad? I bet you could get a HAMB help list for the WHOLE trip to Austin.
    I've been following this post and saying "Go Man Go!"......and heck I bet if you do get to Austin and the motor goes south....one of those guys down in Austin would "loan" you a SBC.........heck, I wish that I was closer, I would loan you one that I had a "Vato" rebuild in a shop cl*** about 2 years ago that is just sitting.
    Even though..... you know already.......your cars are meant' to be driven.........and my pop's and I had the best time ever driving to the Bonneville Salt Flats from Kansas in 'junkyard' motors and we made it there and made it home.
    GO! MAN! GO!
    Chris Nelson
    Kansas
  12. 53sled
    53sled
    from KCMO
    Alex, you can do it. I threw new head gaskets in a 305 with water in the oil, changed the oil twice after getting it running and ran the piss out of it to a few long distance shows.
  13. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    lets pray
    on this motor i scuffed it put high temp gold matalic then h of k base coat. it was a rush . normaly i would have a bare block shot the high temp paint then base then clear you want to keep the mill thicknis down if you want it to last i would stip it if you ceam strip it your taking a chance with your gaskets so homie i guess it all about what your end result you want ill call you
    thats what i did on this one
    been retarded all my life in fact some *** hole on here didnt like me misspelling words and called me a retard heck my misspelling is my signature!!!!:eek:
  14. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    dumb questions are good
    thats what i did is made one out of an old distibutor
    thanxs
  15. Ian Berky
    Ian Berky
    Thanx for the info Alex!! after all my mock ups and mounts are done, im gonna strip it and do it up nice for the cadillac!!! :)
    See you in Austin Alex!!! sorry again about your motor!! :(
  16. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    already riped apart
    close but no cigar
    hey chris thanxs see ya in austin
    yyyyyeeeeeeeeeeeeeeeeeessssssssssssssssssssssss
    im crushed thats whati get for this last minute **** should have got into that motor when i got it it was sapose to be good ha ha
    it is a good motor just needs some spring cleaning
    thanxs
    thanxs groucho part of me says run it but my last motor wasnt 100% i ran like a bat out of hell thow its all a piece of mind i want to drive to kanas and new york so its no biggy to miss austin having no car so im a homo and will fly so waht it will be greater later the rods and the wirst pins were rusty all ready tore of the heads gona send the rods and pistons out to get re comditioned and new rist pins ill have the crank polished the cam looks ok ill sendthe heads out to be takin apart and cleaned will hon out the cylindars lets see what else?
  17. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    no the old motor wasnt bad i could have made it to austin maybe but ill have to cross this bridge sooner or later i didnt want to **** up the 283 just to drive it AGAIN to austin so ill go there both motors and have to good ones mine the rings didnt seat right and was starting to get blow by i think i drove to fast to paso when it was fresh i cant drive 55:D any ways thanxs
    i know i could make a go at it but i figure at this piont so i dont drive to austin this time but at least ill have 2 good motors in the long run one for the 54 and one for my daughters 66 bonni
    thanxs
    i just need to get my ducks in a row quack quack and quite bull ****ing and make **** happeb instead of half stepin!!!!!!
  18. 76cam
    76cam
    Doesn't any one have a motor he can use to get to austin at least???????? Id give you one of mine but I live to far away surely someone got a spare!!!!!!!!
  19. Sorry it didn't work out dude.
  20. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    tore into the motor
  21. That would've ran fine just like that
  22. slammed49
    slammed49
    Run that thing,its a SBC....rust and 2 qts of oil and they go forever...Im using a $400 junkyard 305 from a Tuned Port Camaro,unknown miles,Edelbrock/Holley swapped on...6000 RPM burnouts all day...been everywhere!
  23. daddio211
    daddio211
    Ya know Alex, I certainly can't find fault with your choice. When you saw a problem you stopped, regrouped, and decided to fix it the right way rather than scabbing it together.
    That speaks volumes about you and your shop. This thread is all any potential customer of yours ever needs to read to know you'll do what's right!
  24. -Brent-
    -Brent-
    Aw man, you can hear the disappointment in your voice. ****s to hear you won't make it out there...
  25. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    thanxs ian see ya in austin baby
    thanxs if i realy wanted to make it there i could have i drive there every year thats says more than most who have an able car and dont make the trec i just want the new motor tro be 100 % i drive the **** out of this car i got vegas kanas new york to name a few ventura santa maria to mention a few more ya its a small block it would have ran but **** this motor prob dont have 100 miles on it
    grouch i know it would
  26. MissPrint
    MissPrint
    Just glad you're still gonna make it out, Alex! That's the important part. . .
    Be safe, and see ya in a few days! :cool:
    (Besides, I think you know a "few" ;):) people here. . .we'll all make sure you get around town in style ;) )
  27. Evel
    Evel
    awe man that ****s...sorry dude... either way we will have fun in a-town.. :D
  28. eddie_zapien
    eddie_zapien
    NOOOOOOOOOOOOOOOOOOOOO!!!!!! What a terrible way to start a new week. Sorry man.
  29. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    ya i could have ran it the motor dont even have 100 miles on it rather take the extra time and make her a lil more sound if it was an old motor ya i can see it what would i have to lose ive got to big a driving season ahead see its the way it goes
    thanxs man i never can seem to take the easy route
    ill be in austin tuesday
    thanxs man
    hell ya im da boss
    i rolled the dice and came up hort more vidios to follow already tore the motor down!!!!
  30. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
