I need a large steel spike
Discussion in 'The Hokey Ass Message Board' started by UNDR8D, Mar 26, 2011.
  1. Dirk35
    Dirk35
    Someone else already said it......but you are still asking. You need a Round bale spike from a Tractor Supply store or Farm and Home Store like Atwoods.
  2. newsomtravis
    newsomtravis
    from pville, ca
    think you`ll have to find a piece of 1 3/4 to 2 inch solid round and have a spike machined, find a machine welding shop in your area, shouldn`t cost too much, hell, if your were close to me i could do it for about 30 bucks........
  3. 296 V8
    296 V8
    from Nor~Cal
    Screw the spike ..... it needs a chrome scull :rolleyes:
  4. briggs&strattonChev
    briggs&strattonChev
    the bale spike is a good idea, I would check out a farm supply store (or an old tractor junkyard for that special pre-1964 version). If you need to explain it to them, its basically like the forks of a forklift except this is just a spear that you ram through a bale then lift.
  5. UNDR8D
    UNDR8D
    from Ojai, CA
    The bale spike sounds *****in. I will look into that.
  6. Bad Daddy
    Bad Daddy
    x2 .
  7. lol talk about phalic!! its even got the legs with the old fella between
  8. Solid spike? Hell I bet if you really think hard you can come up some other useless unsprung weight to add to that!
    Doc.
  9. rodl
    rodl
    My thoughts exactly, you don't need length, the chain mesh post caps have around 1/2 to 3/4" 'socket' length. plus the shape will look perfect on your diff. ****!
    RodL
  10. nefareous
    nefareous
    from maryland
    Here is a spike..of sorts
  11. brad chevy
    brad chevy
    Go to the hydralic cylinder dealer near you and pick up a solid pin,alot of them are already machined for the id you need and get busy with a grinder and shape the thing anyway you want it.
  12. SixFive
    SixFive
    Y'know what might solve this problem? Put a floor over it.
  13. CoolHand
    CoolHand
    Alliance Vendor
    I'll machine you one any shape you like, delivered to your door.
    Scratch your idea out on a napkin and send me an email.
  14. slackcat
    slackcat
  15. appaRATus
    appaRATus
    This is a 3 point hay spear, they make all kinds but the "spear" end is basically the same on all of them. You should be able to find an old one pretty cheap.
