Air Scoops
Discussion in 'The Hokey Ass Message Board' started by Wicked50, Mar 26, 2011.
  1. Wicked50
    Wicked50
    I got a set of the tear drop scoops like the ones on "Atomic Punk". They look great on my 3x2 but I have a small problem. The set screw is to high on the scoop to catch the throat of the carb. Do any of you have and ideas that can work. I thought about redrilling and tapping is this my only option?
  2. Wicked50
    Wicked50
    Back To The Top
  3. Bad Daddy
    Bad Daddy
    Redrilling and tapping sounds good. You could also grind a bit off the bottoms of the scoops till they sit low enough for the screw to grab.
  4. Wicked50
    Wicked50
    looking at the carbs the throat is about 1/8 to 3/16 of an inch and the center of the set screw on the scoop is at about 1/8 above that. It doesnt look like there is much to drill and tap a new hole.
  5. Idaho/Dave
    Idaho/Dave
    from Idaho
    I think you have the Badger air scoops, theses are more suited for the Stromberg carbs, which have a taller throat, the cal customs fit better and have two set screws.one option it to make several vertical cuts in the mounting collar and use a large hose clamp that would be hidden under the scoop.Hard to find scoops in good condition, I wouldn't want one to fall off, Dave
  6. Wicked50
    Wicked50
    Ya im sure I got the wrong scoops and I wont be able to use them which ****s
  7. Wicked50
    Wicked50
    So here is what I thought could work how about welding some 2 tabs in the throats of the carbs and drilling and tapping them to line up with the holes in the scoops? Can I get some input.
  8. Soviet
    Soviet
    Get the right scoops or the right carbs.
    or
    Modify the scoops to fir.
    I would go with the former.
  9. Don't weld them....
    Take some sheet metal and make a spacer that goes in the air cleaner and over the neck of the carb. thin metal will work. then you can use the set screw in the metal and a thin hose clamp on the carb. That way the air cleaners stay intact.
    Here's a couple of ideas
  10. Wicked50
    Wicked50
    I like your idea what did you use to make the collar. I was thinking of using a piece of 3" EMT pipe (electrician pipe) and sectioning a piece out of it clamping it down.
  11. Wicked50
    Wicked50
    bringing it back to the top
  12. Wicked50
    Wicked50
    Redrilling and tapping would only leave 1/16" below the set screw which is not safe. Anyone else have an idea.
