Hard and fast slip yoke rules?
Discussion in 'The Hokey Ass Message Board' started by Jim Lohman, Mar 27, 2011.
  1. Jim Lohman
    Jim Lohman
    from Colorado
    Any rules about how much yoke should be hanging out of the tail shaft? Mine is 1 and a 16th inch between tail shaft housing and yoke.
    Jim
  2. Rob Paul
    Rob Paul
    Depends how long your yoke is....
  3. Jim Lohman
    Jim Lohman
    from Colorado
    For 700r/4L60, 70% inside tail shaft approx.
  4. You're close enough to be in good shape.
    My standard rule for a car application like this is to have the slip yoke being 3/4" to 1" from being bottomed out. Dirt car and 4WD applications vary from this.
  5. 69fury
    69fury
    from Topeka
    driveshaft companies will tell you to bottom the yoke, then pull it out 1 inch to measure the length of shaft you need- so you're doing a-ok at 1 1/16".
    rick
  6. Fenders
    Fenders
    What he said. Bottom it, then pull it out an inch or 1-1/4.
  7. Jim Lohman
    Jim Lohman
    from Colorado
    Excellent, thanks rick
