Transtar Kwik Prime vs Euro Classic?
Discussion in 'The Hokey Ass Message Board' started by droplord49, Mar 28, 2011.
  1. droplord49
    droplord49
    from Bryan, Tx
    Could someone that is familiar with Transtar products tell me the difference between their Kwik Prime 2k primer vs their Euro Cl***ic primer. Their data sheets have basically the same description for both. Is one better than the other? Pros/cons of both? Any info would be appreciated. Thanks
  2. droplord49
    droplord49
    from Bryan, Tx
  3. vonhyde
    vonhyde
    i think the VOC's are lower in the euro lines generaly
  4. falconsprint63
    falconsprint63
    from Mayberry
    not sure of the difference, but I've used the quick prime several times with good results.
  5. droplord49
    droplord49
    from Bryan, Tx
    fs63, did you run it over bare metal or did you put down an epoxy or etch first? I'm looking for an inexpensive surfacer that can go over bare metal and body filler on a roof I am chopping.
  6. falconsprint63
    falconsprint63
    from Mayberry
    did use it over small areas of bare metal, but nothing huge. from what I recall of the tech sheet it's ok for use on bare metal.
