I like big girls!!!
Discussion in 'The Hokey Ass Message Board' started by heavytlc, Apr 1, 2011.
  1. 69fury
    69fury
    from Topeka
    That, sir, is a proper truck. Good score!
    -rick
  2. heavytlc
    heavytlc
    It is dirty, I did not say it was covered in red clay mud.
  3. schwerko
    schwerko
    from bristol ct
  4. terry48435
    terry48435
    Sweet, Guess I'm hooked on BIG girls now.
  5. 38Chevy454
    38Chevy454
    Looks nice, you might look into mandrel bent tube. That is what I used for my COE flatbed, got 2x4 mandrel bends from Art Morrison (the high end ch***is guys). I bought two large U-bent pieces for the front and back. See my initial construction of the bed here which shows the rounded corners:
    This picture show before the rear fenders were put on:
  6. Lets see you get pissed off and pound the dash out of one of these beautys!! No carpets no console, no plastic **** or padding. Built for work and driven by men ,and when you hit somethin with these you killed it!!
  7. zman
    zman
    from Garner, NC
    big girls and a hoarder... :D
    sounds like a reality tv show.
  8. HOTFR8
    HOTFR8
    Nice truck. If it was mine I would be building a matching 5th wheeler type trailer to do all the work.
  9. havi
    havi
    And it's made in the good ol'
  10. Strange Agent
    Strange Agent
  11. Reman
    Reman
    from Florida
    Jason that is a great truck. I love it! The only thing I might do before any heavy road hauling would be to store the 272 and add a 390 or such. Would be pretty easy to do. Please post pictures as you update it. Ron
  12. Rickybop
    Rickybop
    Very nice truck!
    But why did you mount the tiny shed on the back?
  13. Tom S. in Tn.
    Tom S. in Tn.
    And a very nice truck indeed. I'd enjoy owning this one, and I have been pondering my next truck.
    Post updates frequently.......... with more pictures please !
    Very nice indeed. I'm seriously considering what the $$ might be if I took on a road tractor project, possibly with a Rockwell tandem from a M-35, and overdriven high so it can be used on open road hwy.
    Tom S. in Tn.
  14. heavytlc
    heavytlc
    I read your build thread on the bed. I am not sure what I am going build. The old girl is much bigger than I was expecting. The cab is normal but the truck is like a day cab semi. I will not be able to get a full 8' bed but it will be 92" wide.
  15. dragsta
    dragsta
    it's a thing of beauty. all it needs is a blower sticking out of the hood...
  16. slickhale
    slickhale
    from Phoenix
    man that thing is well done, i need one
  17. BERNIES WELDING
    BERNIES WELDING
    a little fabrication tip.................
    i have made my own radius corners before and they are very easy.
    1. depending on the size of square or rectangular tubing you are using take the 2 pieces and set them corner so as to have an open notch at the corner
    2. get a piece of conduit or the type of tubing used for comercial sprinkler systems that is usually a .120 wall.
    3. cut a piece the length of the height of your tubing.
    4. now take the section of the tubing and cross cut it so you have 4 equal pieces.
    5. one of the quater pieces should fit perfectly in the corner.
    6. if the section is cut 2 times the thiclness of your square tube you can now use a hole saw the diameter of your tubing and cut out a disk and cut it in quarters and you have the tops and bottoms for your corners and when all welded up and sanded to match the radius of the tubing it will match and no one will be able to tell if it was mandrel bent or you made them.
  18. Silhouettes 57
    Silhouettes 57
    Love that ol truck....drove a '56 stake side hauling plastic pipe back in 1965 in So. Cal. that old Y-block was a running son of a gun!
  19. heavytlc
    heavytlc
    I have also done it using flat plate a torch and hand cutting the top and bottom. I was kinda thinking a 24-37" high bed with a round radius top and bottom. Think vintage welding bed. I will post pics when I get started.
    I was supposed to be in Maxton for the ECTA races tomorrow, but I will have to go to work. I was Having a great day, It just started to ****
  20. 47Ford - 1.5Ton
    47Ford - 1.5Ton
    I'm definately a fan of this thread.....
    Feel free to take a peak at my build thread if you ever wanna daily driver it...
    Nothing like a 2 ton truck on independent front, 4 link rear, all on air, hydroboosted disc brakes and power steering.....
    Mines a a big old girl from 10 feet away but shes a beauty when you look underneath......
  21. havi
    havi
    Only thing I'd change, is to put a 5th wheel receiver on it, and use it to tow cars and such. My 2 cents. Perhaps a 5th wheel in the flatbed. (what I'm looking to do with my F6)
    EDIT: Changed my post to sound less derogatory.
  22. heavytlc
    heavytlc
    I am building a bed, adding cast y block headers and duals. That is it. This one is far from a project. I have plenty of projects. Yes I would love to swap a nv4500/nv5600 and 12 valve ***mings, but that is not going to happen with this truck.
  23. Johnny Wishbone
    Johnny Wishbone
    I love the 57 Jason, one of my favorite one year only body styles. One of the cars for sale isnt the Fairlane is it? Mine still has no paint, but maybe soon?
  24. Gizzy
    Gizzy
    from N.W,Ohio
    Hell Yes...I LIKE it!!!!!!!!!!
  25. HOTFR8
    HOTFR8
    5th wheel or semi trailer would work well considering it has the turntable and as I stated earlier would be what I would do. As for swapping in a ***mins (even though I have on in my F4) when the Y block is such a good motor I have to agree the Y block would stay if I had that truck.
  26. Oldsmobucket
    Oldsmobucket
    awesome truck! i saw it on my way home from work in the orielys parking lot. that truck is awesome.
  27. heavytlc
    heavytlc
    No the Fairlane is not one of them. Actually only 2 are Hamb friendly, and I think they are both heading to new homes. I would keep the Fairlane even if I could not pay the power bill. It is just me and some dogs, not like I worry about a wife or kids eating or staying warm.
    I would trade my 1956 f100 driver for a 1957 f100 fleetside in a heartbeat. I was actually looking for a 1957 panel truck when I found the f600.
  28. patrick66
    patrick66
    Yum! I'd like to drive that.
  29. rockher_man
    rockher_man
    Man...that is one ***y truck! Outstanding!...:cool:...
    "I am in the process of selling 13 car/motorcycles."...:eek:...WOW...sounds
    like there is some "downsizing" goin' on....just curious...where are these 13
    listed?
    Again...excellent score...I'll keep an eye on this thread...I can't wait to see how this ends up!...
  30. AnimalAin
    AnimalAin
    Neat old truck. Have some fun with it.
