Hot Rods Machine turning
Discussion in 'The Hokey Ass Message Board' started by bob giles, Apr 2, 2011.
  1. bob giles
    bob giles
    First attempt at machine turning. Used a 2 inch rolock on 1 inch grid.
      493.6 KB
  2. hrm2k
    hrm2k
    nice stuff !!! I had been thinking about trying this on a couple of new parts for my T
  3. cederholm
    cederholm
    Wow - that looks great. First time eh??!!??
  4. captmullette
    captmullette
    looks really good, whats a rolock?? i need to try it on my dash...
  5. butcherted
    butcherted
    from hagerstown
    Looks great more details please.
  6. The37Kid
    The37Kid
    VERY NICE! What did you use for a guide/fixture? Back in the 1970's when I was at a restoration shop we had a special guide to do the Bugatti dash and firewalls. I always enjoyed doing it, but you never knew how it would look untill you washed off all the valve grinding coumpound.
  7. Eastwood sells a kit for smaller stuff, I used it on the dash of my OT car. easy to use, hard to master. Drill press makes it easier for small stuff. I bet doing a firewall was tricky! Looks great....
  8. Looks Great!
    By the way,,,
    What kind of valve covers on your engine,,looks like old Cal Custom kinda?
  9. Nice job! We have some 3/4" rolocs at work, I was thinking of trying. What grit did you use? or did you use the scotch brite type rolocs?
  10. captmullette
    captmullette
    what is a rolock and where do i get some, one, it , them,????
  11. thegrappler
    thegrappler
  12. Lots of threads on this with extra info "engine turning" will get anyone looking tons of hits.
    I tested many methods. Rolocs work ok but Cratex sticks/mandrels work the best in my experiments.
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Layout looks great nice job.
  14. 1929Essex
    1929Essex
    i did most of my interior like this. Much easier with a drill press, just took a roloc wheel and cut down a scuff pad. i just hope it isnt too shiny when the sun hits it.
      404.7 KB
  15. That looks killer. Nice work.
  16. X2....more details please. (looks great BTW!)
  17. FoMoCoPower
    FoMoCoPower
    3m Roloc discs
  18. rd martin
    rd martin
    from indiana
    any up close pics? thanks
  19. 5window
    5window
    I'd like to know what the base metal panel was before you started turning.
  20. RAY With
    RAY With
    Turned out nice. I haven't done it in many years but seeing this may give it a shot again
  21. captmullette
    captmullette
  22. putz
    putz
    from wisc.
    for small swirls , i read where you can use a wooden dowel , using a drill press . i haven,t
    tried this yet but i,m sure it would work .........................
  23. 60 Plymouth
    60 Plymouth
    from UK
    Yeah, wooden dowels and some emery worked great on aluminium for me, using a drill press.
    Anybody know how you do it on somthing 'in situ'? Like if I wanted to do it on a dashboard without pulling the dash? Or a vintage Bugatti engine block when I get the money . . .
    When I do it with a pistol grip it just skips all over the place, no matter how well I hold it.
  24. 117harv
    117harv
    I did a small piece in high school but can't remember, is there a differance in the final look starting with raw un polished aluminum, br*** etc. as compared to a polished piece?
  25. The37Kid
    The37Kid
    You need to make a guide, we had one when we did the Bugatti work. Just picture a long strip of aluminum with a series of holes evenly spaced then cut it in half. The half hole is the guide for the shaft in the drill. Hope this discription works for you. Bob
  26. 60 Plymouth
    60 Plymouth
    from UK
    Nice one - that makes a load of sense. You still use an ordinary power drill with dowel to do the marking?
    When I did my aluminium it was just bar stock, didn't do anything to it other than the engine turning and came out ok. Used 600 or so emery on a block of balsa inside a fitting that took a socket (they were the nearest things to hand that went in the pillar drill). I'd never done it before, it was just an experiment to see how it went. Went very well. I didn't use a guide or compound table either (I would if I cared how it looked). The spacing was around one radius of the swirl, since that looked about right. Each row was offset so the swirls in the row below went 'between' those in the rows above. What amazed me was how uniform it looked without trying, though again, if you care, use a guide.
    The only thing with the emery was that it would occasionally hold a bit of grit, and you'd see that as a circle drawn into the swifl pattern. I ws only messing around so it didn't matter, I bet there are some much better methods mentioned here.
  27. need louvers ?
    need louvers ?
    for dash board stuff, I use a Cratex stick slid into a chunk of copper tubing to help support it, and come up with about 5/8" swirls. The copper tubing helps supprot around the cur***frence and provides a cleaner, rounder swirl each time. I usually work free hand on the drill press, starting at the upper left hand corner, half on and half off on both sides. I work left to right from there moving one half a swirl at a time until I reach the end of the part. Slide it all the way back to the left and drop down one half swirl, advance one half swirl and work one half swirl at a time to the left... Repeat until your brain shuts off!!! I have done lots of stuff ranging from dash boards and step plates to the 2 36' x 8' monument signs at Phoenix International Raceway park using this method. Bigger turning mandrel on the signs of course! Sorry I don't have any pictures to post at this time. I'll shoot some and post soon.
  28. The37Kid
    The37Kid
    Besides the guide there was a sheet of plywood with a tape or yardstick on both sides to aline the guide so you were running straight parellel lines. The aluminum sheet was screwed to the plywood and covered with a course valve gringing coumpound, we bought it in one gallon cans from somewere. Rubber pads were glued to a fixture that fit in a hand drill. This fixture had a ball and pin ty[pe oy universal that allowed the pad to have sopme freedom of movement. Worked well. Bob
