stewart warner electronic tachometer
Discussion in 'The Hokey Ass Message Board' started by crashhaley, Apr 9, 2005.
  1. crashhaley
    crashhaley
    from san deigo
    Any one know how to hook one up? Has blue box thing inside with 1 though 4 little switches, and on back aux, sig,pos, and neg. thanks
  2. Mr 42
    Mr 42
    from Sweden
    The switches probably makes it possible to change between 4,6,8 cylinder engine.
    Pos connect to a psotive lead from the ignition switch,
    Neg connect to ground,
    Sig connect to distributor points
    Aux?? May its for the light inside the tach?
  3. Automotive Stud
    Automotive Stud
    Is this a fairly new tach or an old two piece unit?
  4. crashhaley
    crashhaley
    from san deigo
    New tack
  5. Automotive Stud
    Automotive Stud
    I know someone here will have your answer. But you can always try www.stewartwarner.com I couldn't find the answer on thier site but you can email them tech questions.
  6. desoto
    desoto
    from Ayer, MA
    The DIP switches are to select the number of cylinders. I take it that this is a metal-cased unit. The plastic-cased units are junk. I believe these have a rotary switch instead of a row of DIP switches.
    In any event, if you pick it up off the flkea market table and the needle DOESN'T drop to zero. DON'T buy it. It can't be fixed w/o sending it back.
  7. crashhaley
    crashhaley
    from san deigo
    Thanks i couldn't find it on thier site either.
  8. crashhaley
    crashhaley
    from san deigo
    IT has a row of dip switches. And the needle is at zero. Thanks for the imput.
