Rivet Removal - Is there a right way?
Discussion in 'The Hokey Ass Message Board' started by Gigantor, Mar 29, 2011.
  1. rockable
    rockable
    Way to go! That air hammer beats the hell out of swinging a BFH! Doesn't it?
  2. Gigantor
    Gigantor
    Thanks for the pics and testimonial! Rather than spend this weekend removing rivets,I spent it reattaching my plow to my truck after one of the claws snapped clean off... the snow was HEAVY. I can't wait for real spring.
  3. Left Turn
    Left Turn
    from Omaha, NE
    Real Spring?? what's that?
    I second the drill/air hammer method... or, if it's something heavy rip the heads off with a chisel bit in the air hammer, then pound 'em out with a punch bit.
    grinding, and grinding, and grinding, and then pounding and pounding and pounding... is soooo not worth it.
    I tried using a spot weld cutter once too.. center punch the heads, and start drilling... broke quite a few spot weld cutters... Snap On has a great warranty though!
  4. Gigantor
    Gigantor
    Real Spring? Well, I could see gr*** the other day and was walking around outside in a t-shirt. Friday morning the sky opened up and dumped 14 inches all over everything... most of it melted on Saturday... but it just started snowing again about an hour ago.
    Pretty good excuse to turn the heat on in the garage and get at them rivets...
  5. Pensive Scribe
    Pensive Scribe
    This is the way. The thinner you can make the rivet wall with out going through the easier they are to punch out. This has worked the best way on the thousands of rivets I have removed.
    Doug.
  6. Dave Zapatka
    Dave Zapatka
    Beat to fit. Paint to match !
