Rochester 4g carbs on a blower?
Discussion in 'The Hokey Ass Message Board' started by Spyder, Apr 6, 2011.
  1. Spyder
    Spyder
    from Houston
    Have you ever done it, or seen it done successfully? I'm making progress piecing together a blower set up for a 351W and am wondering if I can use a pair of 4g carbs that I have.
    If I don't have to go buy carbs, the project will come together sooner.
    I am planning on mild street motor with about 8 pounds of boost, maybe 450hp.
    I haven't torn into the carbs yet to see what it would take to boost reference them, but they are real simple carburetors, so I expect it shouldn't be too hard.
  2. I'm sure it was done back in the day. The only thing I can see as a problem would be if you were running a big blower it may restrict it, the more you resrtict it the hotter your charge will be when it hits your intake.
  3. Spyder
    Spyder
    from Houston
    The blower's pretty big, an 8v-71, but I plan to run it slowly, say 15% underdriven. I had looked up the CFM ratings for the carbs, but now I forgot. The're small, like 500 cfm
  4. I was thinking that they weren't rwal big. If I was going to run 2 4s on one I might lean towards a pair of Carter AFBs. You may be alright with the 4gs but before I invested cash in them I would try and sell or trade them. Just my .02
    They would be perfect for one of these fellas with a small displacement motor that wants to run 2 4s.
  5. squirrel
    I'd look around for some old AFBs if I were you. or even a pair of Holley 1850s.
    Or some WCFBs or something
  6. Paul
    Paul
    Editor
    my Rochester book says some positive things about the 4GC
    they can be made to perform surprisingly well,
    although the reference is not specific to blown applications,
    and it looks like to performance tune they need surgery..
    not just simple parts swapping like some of the more popular choices
  7. Mutt
    Mutt
    "I'm making progress piecing together a blower set up for a 351W and am wondering if I can use a pair of 4g carbs that I have"
    Have you found a manifold for the 8V71 yet??
  8. 5096PS
    5096PS
    from iowa
    I've run them for years,,had to,as does all Stock/Super Stock 283/220 and 327/250 engine combos. I will say one thing,many SS guys run well in the 9,000 RPM range with little problems,,but boy,,they are really small. One good thing,they are a dual float design and hold a lot of fuel in the side bowls,,so running out of fuel or having to run m***ive pressures aren't a problem. The sharpest guy around on these carbs is Dean Oliver in Stuttgart Arkansas. He is who most of the Stock/ Super Stock guys go to for carb modifications,,within the rules of NHRA. He's a good guy and probably give you the best info if you chose to go this route. He is at
    deano@cl***icnet.net
  9. carbking
    carbking
    If it is a pull-through, I don't see a lot of issues.
    If it is a blow-through, sealing the accelerator pump is going to be a challange; and depending on boost, you might have to fab baffles to fit inside the float pontoons. The standard "vacuum seal" could be machined for the throttle shafts. Sealing the idle screws would not be difficult. If you have the models with the idle air byp*** design, sealing this would require some doing.
    As to ratings, while specific CFM ratings were not published; various 4-G series carbs were made from roughly 375 to 625 CFM.
    Jon.
  10. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Them's Stromberg Aeroquads.
  11. Spyder
    Spyder
    from Houston
    Well, there is no such critter as a 8V71 intake for a 351w, or anything else. I bet you knew that. I have an EFI lower intake that I'm adapting. I cut one piece of plate to match to top of the intake, and another to match the bottom of the blower. They are pretty similar. When I have the distributor and pulley's mocked up, I will put the plates together.
  12. Spyder
    Spyder
    from Houston
    As always, I appreciate everyone's thoughtful responses. The shortcomings I had seen for the 4g was that most of the one's I've come across have an odd ball bolt pattern and air cleaner size. They are also tall. The blower is already going to be sticking way up there. But the price is right, and they have a more vintage look than many carbs out there now.
  13. Spyder look in our cl***ifieds. There was a pair of AFBs not blower referenced yet but good runable shape complete with linkage for about 325 to 350.
    Sounds like a lot of cash but you would be in there like swimwear. they are real old AFBs also and not new Edelbrocks so you could even tell everyone that they are real old school carbs.
    Hell I'll see if I can find the link for ya.
    Ok here's a pair that Desoto has:
    http://www.jalopyjournal.com/forum/showthread.php?t=557454&highlight=afb
    This is the pair I was thinking about.
    http://www.jalopyjournal.com/forum/showthread.php?t=558031&highlight=carter
  14. squirrel
    I thought there was something strange looking about them...thanks for the correction
    Early AFBs have the small air filter flange too don't they? but they're probably easier to put right next to each other than 4Gs.
  15. carbking
    carbking
    The very early STANDARD bolt pattern was almost square (3 3/4 x 3 7/8). This bolt pattern was used on:
    Carter WCFB 1952 - approximately 1956
    Holley 2140 (all)
    Holley 4000 (all)
    Rochester 4G 1952 - approximately 1956
    Stromberg 4A (all)
    Of the above the Carter WCFB and the Stromberg 4A are the easiest to modify The others may be modified by those who know what they are doing, and don't mind fabricating parts.
    The "approximately" in the time line is due to the fact that not all makes switched to the newer 4 1/4 x 5 9/16 rectangular pattern at the same time.
    Jon.
  16. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Yes, and I'm not sure what determined whether AFBs got the 4 7/32 or 5 1/8 inch lid. Every factory Chevy AFB I've seen had the smaller opening, except for the 400hp 409 carb. Pontiac AFBs always had the smaller top, but Mercury and Lincoln AFBs used the larger top right from the start in '57.
  17. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Oldsmobile went to the larger bolt pattern in '54 while Cadillac, for some reason, stuck with the small pattern through '56.
  18. Spyder
    Spyder
    from Houston
    Ok, I now have a set of AFB's as recommended. I had one, and just found another to match it. It was much cheaper than Holleys. Thanks
