1960 Starliner build thread
Discussion in 'The Hokey Ass Message Board' started by Starliner352, Mar 16, 2011.
  1. carbuilder
    carbuilder
    Well the old girl put up a fight but the body is off of the ch***is now & Dave can pick it up & do his thing to her while we keep m***aging her body.:D
    Next week more to come.
  2. ****! I asked Danny to remove all the rust from the body - and THIS is what I get back! :rolleyes:
    Oh well, we're making progress..
    Ch***is and ***orted panels going off to media blaster next week.
  3. carbuilder
    carbuilder
    A few more panels were made today.
    Tomorrow Max will start t******* the panels & welding them in one at a time. It will all be tig welded then ground & worked as much as we can with in reason. We are on a tight hours schedule on this car so we wont be able to metal finish as much as we like but it will still be high quality, more to come.
  4. Surfrider
    Surfrider
    1960 Ford Starliner, my all-time favorite car, all-time.
    Love to get one, by the time my kids are out of college, I'll probably be too old to work on one...much less afford too!
    Keep up the good work, I'll keep drooling, er watching the build.
  5. Zerk
    Zerk
    Love the Starliner...but then I love all '60 Fords.
    A gal in my school had a slightly rusty Starliner in that pale orchid color. I don't remember much about her, but the car...
  6. carbuilder
    carbuilder
    Got the RR qtr lower section cut off & oops more rust out repair so more panel fab work.
    Then a little por 15 coating.
    One more small patch then should be able to put the outer hand formed lower rear quarter patch on.
  7. carbuilder
    carbuilder
    Another small inner patch had to be made.
    then POR 15 coated.
    Several of the trim bolt holes are rotted so a die for forming the square holes to match was made & patches made. For us it is all about doing the details correct.
    More to come.
  8. Midwest Rodder
    Midwest Rodder
    Very cool build. There is a Starliner a few miles from me in the woods with 9 or 10 other early cars, I have worked on the land owner for 4 years now to buy them but he wont let them go. Now the Starliner in about 8 in in the dirt and I am sure the entire lower half is no good anymore.
  9. My first car was a 60 Starliner, had the 360hp 352 motor and "three-on-the-tree" with overdrive. No PS, no air.
  10. carbuilder
    carbuilder
    Oooo no more rust & patches.
    More to come.
  11. Sweepspear
    Sweepspear
    I have loved the looks of the '60 Ford, especially the Starliner long before they were considered desirable. If only I had bought them then.
    Hell, I was brought home from the hospital in a '60 Fairlane 500.
    Look forward to following this thread!
  12. 60galaxieJJ
    60galaxieJJ
    Where are you going to buy your wiring harness from?
  13. Buy? Wiring Harness?
    Not at that point yet. Why do you ask?
  14. 60galaxieJJ
    60galaxieJJ
    Because I'm going to end up buying one soon. Just curious
  15. carbuilder
    carbuilder
    Max got some more progress on the Starliner today.
    There is still quite a bit of welding & grinding to do on this back corner but it is starting to come together. Yes that is the very rust thru trunk floor you are seeing thru where the hand made repair panel will go.
  16. carbuilder
    carbuilder
    Max got the rear corner welded up, ground, planished & into DA 80 grit..Plus some pin hole sand blasting where the side trim goes. Remember these are all hand formed panels, no after market bad fitting junk here.
    More to come as the build progresses.
  17. Here's the work that's going on with the ch***is.
    Removing the rear suspension is a piece of cake. Racecar is waiting impatiently for that big piece of steel to get out of the way so race season can start.
    Turns out that removing the front suspension is a real trick without the body on. Nothing to push against to compress the front springs. It was a little tense releasing the upper A-arms but no big deal. Dig that crazy camber!
    Now off to the sand blasters to get everything cleaned up.
  18. slammed
    slammed
    You are a metal magician. This work fantastic.
  19. You are right about that! Looks even better in person.
    This Starliner is on the way to being much mo betta than I had originally planned!
  20. moonmerc
    moonmerc
    FYI the local vintage ford parts place here in San Dimas CA has a NOS grill for your starliner hanging on the wall in it's original packaging.....
  21. sololobo
    sololobo
    Good progress bro, my favorite Starliner is the one I am seeing at the time. These rare cars are so hip, best of luck getting that baby eating some white lines soon! ~sololobo~
  22. carbuilder
    carbuilder
    I have a very talented young man in Max working with me so between the 2 of us we can build just about any thing in sheet metal & make it look right it just takes time & time cost's $$$. Any body else need there project done pm me.
  23. flynbrian48
    flynbrian48
    Any progress with the spindle/brake swap? I have a set of those on my '59 T'Bird, haven't finished up yet, and wondering how you think it'll work out. The steering arms are so different in length and angle, I'm not sure I will use them now that they're on the car.
    Brian
  24. Will be starting on those spindles next week, after I get everything up to the blaster. I have *heard* that they will work. I don't know if the Ranchero's spindles are the same as the same as the Grananda setup which I know does work.
    Will let you know when I find out.
  25. Thanks for the tip Merc. I don't need it, but another Star owner visiting here might.
    And just plain old thanks lobo.
  26. flynbrian48
    flynbrian48
    LTD II, Ranchero, Cougar are the same, but I think the Granda ones are different. The ball joint tapers are the same as my 'Bird, and they're on ther car with the tie rods attatched, but haven't driven it. I'll be interested to know what you think of them.
    Brian
  27. carbuilder
    carbuilder
    Got the rear lower quarter tacked then fully welded, ground & DA80 grit.
    The right rear quarter is starting to come together & more to come.
  28. carbuilder
    carbuilder
    A Little more progress on the front section of the r quarter.
    Next a little DP red prim on the lower section.
  29. carbuilder
    carbuilder
    Today Max got the patch fit & welded in in the right rocker & at the door corner.
    He than started cleaning up the inside of the right door & made a few patches for some rust thru.
    More to come.
  30. 60galaxieJJ
    60galaxieJJ
    Damn I'm loving all the progress!
