1949 - 1954
Discussion in 'The Hokey Ass Message Board' started by awin4sin, Apr 7, 2011.
  1. awin4sin
    awin4sin
    from las vegas
    i have a 1951 chevy styleline deluxe coupe i have an lq9 motor i need to know what rear end and width i should look for
  2. xmlc216x
    xmlc216x
    from MS
    A tri-five chevy or 4wd s-10 rear end is probably the most common swap? They are both a good width for these cars. I've read about people using certain camaro rear ends, but I think they're a little on the wide side. I'm sure there is a ford 9-inch that has about the right width and would probably handle the 6.0 liters power better.
    Hope this helps!
  3. Chevy54
    Chevy54
    from Orange, CA
    I believe the width should be like 54 inches plate to plate to center everything up. Its been awhile tho since ive measured mine.
  4. awin4sin
    awin4sin
    from las vegas
    i forgot to say the motor has 340 hp
  5. awin4sin
    awin4sin
    from las vegas
    yeah i thought the same thing about the 9 inch . i went and bought a versailles rear end that is 58 and 1/2 wide but a hot rodder here told me i wanted to be narrower like from a camaro
  6. mine had 10 bolt out of a 69 nova. worked quite well.
  7. allengator
    allengator
    from Keller, TX
    My 51 sedan delivery came to me with a 57 rear end....
  8. AAFD
    AAFD
    from US of A
    Camaro 8.5" 10-bolt or just get a 9" if you plan on making more power.
  9. aldixie
    aldixie
    Mine is out of a 78 Camaro, width is perfect. I'm running skirts and the original steels.
  10. Sam Navarro
    Sam Navarro
    I am running a 67 Camaro rear end with 308 gears.
