inline 6 help please
Discussion in 'The Hokey Ass Message Board' started by hayride63, Apr 11, 2011.
  1. hayride63
    hayride63
    i have a 63 ford f100 not a unibody it has a stright 6 in it my question is how do i find out the cubic inch? i have read that the had 223 240 and 300 ci engines the dist is on right side and intake and exhaust manifolds are on the left all the other ones i have seen are on the right side please help me so i can get a carb and water pump thanks for your help:confused:
  2. sixgun
    sixgun
    from Portland
    Facing the Car? I have a 223 and the exhaust/intake are on the drivers side the distributor is on the p***engers side
    you could check out fordsix.com they have lots of that stuff
  3. Fordsix.com should do you right. Got any pics of it?
  4. Mr48chev
  5. 223 - great little engine
  6. dvzdeathtrap
    dvzdeathtrap
    from austin, tx
    if you can get the casting #'s off the block maybe these guys can help you determine the size. -DVZ
    http://www.inliners.org/
  7. hilbily666
    hilbily666
    from georgia
    I have a 300 six and the dist is on the driver side and carb and manifolds are on p***enger.
  8. HOTFR8
    HOTFR8
  9. hayride63
    hayride63
    my valvue cover does not have bolts threw them. and the exhaust and intake are on drivers side
  10. hayride63
    hayride63
    im not sure how to post a picture
  11. pasadenahotrod
    pasadenahotrod
    from Texas
    You likely have a 240 or 300 truck six in your 63 Ford pickup. Knowing Ford if your truck is a late production 63 it may have had the "new" engine installed as a running change.
  12. The Big M
    The Big M
    Exhaust and intake on the driver's side means it's a 223 or 262, most likely 223. Earlier 223's had the two studs in the middle of the valve cover, later ones had bolts around the outside.
    They were produced from 54 through 64. The 240 wasn't offered until 65, and had the intake and exhaust on the opposite (p***enger) side.
  13. Mr48chev
    You can click on go advanced and to the right of the happyface on top there is a paper clip, click on that and it will let you attach a photo from your computer or you can use Photobucket or Flicker or ?? photo host to post it. Usually by copying and pasting the IMG link on one of those sites.
    If you can't figure it out email the photo to me Mr48chev@yahoo.com and I'll post it for you. I'm going to be outside working on the work car a lot today and not around the computer so it might take a while today.
  14. ClayPigeonKiller
    ClayPigeonKiller
    If the engine is original, it is NOT a 240/300. Ford put that family into production in 65.
    Intake and exhaust on 240/300 is on the p***enger side.
    Intake and exhaust on 223 is on the drivers side.
    And, in case you were wondering:
    There is little discernable external difference between the 240 and 300.
    They share the block and external accessories. 240 usually has 1 groove crank pulley, 300 has 2 (or more on late model, pre-serpentine belt systems)
    The 223 block is different, it takes a different bell housing than the big block sixes.
    Adam
  15. hayride63
    hayride63
    217181_1658052931331_1237361552_31369723_3180513_s.jpg here is pic guys
  16. hayride63
    hayride63
  17. Mr48chev
  18. hayride63
    hayride63
    thanks for all the help guys truly apreiciated
  19. hayride63
    hayride63
  20. Hotrod1959
    Hotrod1959
    mileage-maker good engine....
  21. The_DropOut
    The_DropOut
    Hey Brother, Keep that Buzzin-Half Dozen rollin' !!
  22. conormulroney
    conormulroney
    Carb should be a Holley 1904 and that 223 will probably run forever even looking like it does. They are pretty bullet proof; I've been trying to kill mine for 10+ years with no success.
    Conor
  23. hayride63
    hayride63
    it is bullet proof drove it from sac to anitach billet proof with a quart of oil ran like a top
  24. Crunk Bones
    Crunk Bones
    from Tennessee
    That be the 223. I pulled mine out of a field were it had been sittin for years. Got it to my house were it just sat. Sold it and it just sat. Bought it back a year later and finally got it ready for the road. Fired it up the first time and it aint had problems yet..... except that fuel gauge that reads a half tank ALL the time. I carry a gas jug with me now.
  25. 62RatRod
    62RatRod
    Y'all are making me feel bad for replacing my 223 ;( It's going to a good home tho
