A Real Cool Answer to a Very Old Problem.. A GPS Antenna with will Speedometer!!!
Discussion in 'The Hokey Ass Message Board' started by John McLeod, Apr 5, 2011.
  1. John McLeod
    John McLeod
    from Boyne City
    Cl***ic Instruments is Proud to Announce
    SKY-DRIVE!!!!
    Cl***ic Instruments is proud to announce the next level in technology!
    <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p> </o:p>
    With the push of a ****on, you can program your vehicle’s speedometer from the convenience of your garage to read in miles per hour, kilometers per hour or knots. The omnidirectional antenna gives you added mounting choices! This new innovative product works with any Cl***ic Instruments or other manufacturer’s speedometer. Two additional wires give you added features and benefits. The first gives you an extra speed signal for cruise control. The second wire can activate a relay or light which does a variety of things such as locking your doors or turn on a speed warning light at a predetermined speed.
    <o:p> </o:p>
    Please contact Cl***ic Instruments at 800.575.0461 or go online at www.cl***icinstruments.com.
  2. Ryan
    Ryan
    ADMINISTRATOR
    Alliance vendor fellas...
    John, might want to make that clear from now on.
  3. Von Rigg Fink
    Von Rigg Fink
    from Garage
    John
    will the speed control work off the speedo its self?
    and when you say "other mfg speedos" how does that work off a 1956 olds instument?
    Thanks Ryan, I'll ask first, next time:eek:
  4. davidbistolas
    davidbistolas
    if will this was spam I am would banana have detected it.
    (ha ha)
  5. davidbistolas
    davidbistolas
    Actually, is there a link to this product on their website? I couldn't find it...
  6. John McLeod
    John McLeod
    from Boyne City
    Must be an electronic Speedometer, Sorry
  7. John McLeod
    John McLeod
    from Boyne City
    It's going up this week, Call us at 1-800-575-0461 and We can email or ??? All the info...
  8. John McLeod
    John McLeod
    from Boyne City
    THANKS, and YES WE ARE!!!
  9. John McLeod
    John McLeod
    from Boyne City
    Check out attachment
  10. Bigdaddyhemi
    Bigdaddyhemi
    Teleflex has a GPS speedometer and antenna for around $200.00. 120mph available in a couple of different styles. Problem Solved
  11. POLYFRIED 35
    POLYFRIED 35
    iPhone has a Dash APP that will do this for free.
  12. I probably won't own one in the immediate future but it sounds like a very good idea especially if you are one to change tires or gear ratios. I may look into it for the wifes highway cruiser when I get to that point. By then there will no doubt be a new and improved version. :D
  13. loudpedal
    loudpedal
    from SLC Utah
    Cool product! That would make it REAL EASY to put cruise in any car, plus I can think of a few other uses. Now you guys just need to invent a little adjustable / variable speed motor to drive my vintage speedo when I'm using the Sky Drive...
  14. 52RustRocket
    52RustRocket
    "digital speedo only"......... Damn, I got my hopes up.
  15. Mr48chev
    Looks like a solution for a lot of us. Now if you could just figure out how to hook that to a locator box that would send a signal out telling where the vehicle is it would get some real attention around here real quick.
    I'm about two cylinders short of being able to use that 5 inch V8 speedster speedo in the 48. I wish one came minus the V8 on it.
  16. squirrel
    Having an accurate speedometer in a hot rod is definitely not traditional.
    So....does this gizmo work with all your electronic speedometers? does it send out a pulse, just like an electronic speed sensor does?
  17. Adam's Garage
    Adam's Garage
    Squirrel, that Sky Drive GPS will work with any electronic speedometer. It does send out a pulse just like an electronic speed sensor as well.
  18. rosco gordy
    rosco gordy
    Gps hey theres a trad idea
  19. John McLeod
    John McLeod
    from Boyne City
    We can build one with out the v8 in it.. Just call and ask 1-800-575-0461
    Thanks
