X member for 49-54 chevy?
Discussion in 'The Hokey Ass Message Board' started by choptvan, Apr 12, 2011.
  1. choptvan
    choptvan
    Does anyone have a good company that they have used for this? TCI has a bolt in one, but is there a company that has a more complete one? Or anything comparable? Thanks in advance.
  2. BadLuck
    BadLuck
  3. 1bdsinner
    1bdsinner
    from phoenix
    nice... I have added it to my favorites for when i convert mine to open driveline......
  4. gsport
    gsport
    are you talking transmission cross member?? it's an easy make out of some tubing and flat stock, and it's now a bolt in.... here's a picture of mine
  5. choptvan
    choptvan
    Great! Thanks guys! What about K members?
  6. blown240
    blown240
    from So-cal
    I dont know of anyone that makes a K member. If you are just going to open drive and need to mount a th350 or T5, then you can make a X-member for about $20-$40. Like the pic above, just cut out the center of the stock X-member and bolt in some sturdy square tubing that doesnt curve up.
  7. choptvan
    choptvan
    thought so. Thanks.
  8. lorax54
    lorax54
    from Denton, TX
  9. atomickustom
    atomickustom
    You can use the original K-member no problem. Just make a nice, heavy plate to bolt to the top of the K-member that extends back far enough to bolt onto your trans mount. I have a 350/Turbo 350 in my '53 with the original K-member, no problems. Just use heavy enough steel so it doesn't flex all over the place.
    Ch***is Engineering sells them, but I just made mine:
    http://www.ch***isengineeringinc.com/page30.html
  10. erock805
    erock805
    Thanks for this post. Have to redo mine too.
