help finding: '61-'66 ford f100 frame clips
Discussion in 'The Hokey Ass Message Board' started by azratrod, Apr 13, 2011.
  1. azratrod
    azratrod
    from Az
    here are some pictures of the 3 clips i need for my frame. if anyone has these in good used shape or knows where i can get them new please help me out. thanks
    clip #1 top view
    clip #1 side view
    clip #2 top view
    clip #2 side view
    clip #3 top view
    clip #3 side view
  2. fomocochoptop
    fomocochoptop
    Clip 1 and 2 look very similar to clips used in the engine compartment
    Of a mustang
    What does clip 3 hold and what area is it in?
  3. I've seen # 1 on my '64 Merc I just don't recall where and are usually coated in plastic used for clipping wires to frame or sheet metal. # 2 is still used by Ford it is called a Type 66 in the Standard and Utility Parts Catalog usually used for brake and fuel lines.
  4. azratrod
    azratrod
    from Az
    #1 im pretty sure is for the wiring. it just clips onto the frames edge. the other 2 are for fuel and brakes
  5. flyboy89
    flyboy89
    from So. Cal.
    Try Hilco Fasteners in Garden Grove, Ca. They have alot of that kind of factory fasteners.
  6. Atwater Mike
    Atwater Mike
    Hilco has chrome acorns in most sizes!
    9/16" are $1.38 apiece...probably why you don't see too many.
    Couldn't find clips, though.
