sbc H.P guess...
Discussion in 'The Hokey Ass Message Board' started by smashin54, Apr 15, 2011.
  1. smashin54
    smashin54
    from Miami,FL
    hey im building a 70's sbc and was wondering if anyone has built one similar to my specs and can shoot me a guess on the h.p ill be looking at.
    its a 350 .60 over has stock stroke rods/crank,flat top 10.2.1 pistons,
    -comp 280h cam (230 duration @ .50/ 480 gross valve lift)
    -1.5 roller rockers,
    -305 heads ported exhaust/ ported & polished intake ports, 1.96 intake valves and 1.4 exhaust.
    -edelbrock performer rpm air gap intake manifold
    -750 d.p demon (no choke,vac*** secondaries)
    any help would be greatly appreciated...
    thanks in advance
  2. tims37chevy
    tims37chevy
    from Minnesota
    I'm guessing a little better then 300 hp
  3. Careful with the 305 cylinder heads on a 350 with flat top pistons !!! >>>>.
  4. smashin54
    smashin54
    from Miami,FL
    ooh ooh why's that?
  5. Compression Ratio !! Have you ccd them ?? >>>>.
  6. smashin54
    smashin54
    from Miami,FL
    Im pretty sure there 58 cc?
  7. smashin54
    smashin54
    from Miami,FL
    And what i know they were never shaved
  8. 26 roadster
    26 roadster
    you must be in the hole a lot, I would figure about 11:1 and be conservative.
  9. smashin54
    smashin54
    from Miami,FL
    Sorry guys its the first motor i put together... Thanks for the replies and do you think there would be a major problem with piston to valvr clearance?
  10. smashin54
    smashin54
    from Miami,FL
    Do you think this type of compression is ok for a daily driver On 93?
  11. those heads are the bottle neck, not sure of hp guess on that combo usually see 350 2.02 heads with that set up and hp is around 350 maybe more with better ported heads.
  12. smashin54
    smashin54
    from Miami,FL
    So i think i see a cylinder head upgrade in my near future
  13. if the heads were aluminum 11:1 would be easier but not as easy on cast heads, unless you want to retard your timing just to make it work, best thing would be to shoot for 9.5-10.0 to 1 with that cam and cast heads with todays unleaded
  14. dart s/r cast heads......check em out
  15. 48 Chubby
    48 Chubby
    58cc on a true flat top 350 squeezes to about 12.25 to 1.
    54cc 305 heads (both are pretty common) about 13 to 1.
    These are rough figures- your squeeze may vary slightly.
    If you plan to run it on the street you better know how to tune and jet properly.
    With the set up you have, these heads leave about 40 hp laying on the table
    compared to 64cc heads with 2.02 X 1.94 valves, not to mention the h***el
    It's yo money dog-pay up and take yo choice.
    Just my opinion- 305 heads do a pretty good job on 305's.
  16. smashin54
    smashin54
    from Miami,FL
    Any suggestion on what brand/ specs i should be looking for On heads?or any factory heads that will work?
  17. smashin54
    smashin54
    from Miami,FL
    Will look into them thanks
  18. smashin54
    smashin54
    from Miami,FL
    Thanks for helping me out it was really beating my head..i appreciate the helpni get here on the hamb alot...it has saved my *** a bunch of times
  19. just checked there website they are now called dart iron eagle s/s heads $560 a pair from them i would check summit, see if they are cheaper......
  20. 48 Chubby
    48 Chubby
    Scoggins-****y Chevrolet sells new Vortec heads with the big valves and clearanced for up to .550 lift. Price dances around a bit. You can check on line for the going rate.
    Most bang for the buck out there.
  21. Yeah and if you use the 305 heads you'll get a lot of practice working on it !!! >>>>.
  22. smashin54
    smashin54
    from Miami,FL
    Lol i think ill take the easy way out and order some good heads to save the h***le..really liking the look and price of the dart iron eagle s/s heads so i guess ill look around for the best price and just order them....
  23. smashin54
    smashin54
    from Miami,FL
    Just checked my build sheet and there flat top 4 valve releif cut pistons... Do you guys think that may help my issue or shouldvi just stop matching fire with fire and get some heads?
  24. ddawg16
    ddawg16
    from So CA
    I had something close to that in my 67 Camero many many many years ago....except I had the 2.02 FI heads (double camel hump).
    300 HP? I really doubt it....close maybe....as noted above....heads are your problem....you really got to get those intake valves larger.....
  25. Blown Mopar
    Blown Mopar
    from abc
    Here's something I know. The way to make a 305 perform a whole lot better is to use 350 heads. I don't think it works the other way. Get some 350 heads with 2" valves and you will have a much stronger engine. Or if you have a little more cash the Vortec heads are even better.
  26. 39coupeute
    39coupeute
    from australia
    48 chubby took the words out of my mouth.vortec are great heads mate has them on a 350 with around 400hp
  27. I'd say at least 25
  28. unkledaddy
    unkledaddy
    EQ Cast Vortec Heads are a great bang-for-the-buck.
    Do a search on here as there have been a couple of lengthly threads on them lately.
    You can check with Mike Rogers at Rogers Performance if you're interested.
    http://www.rogersperformance.com/EQ.htm
    I got my EQ heads from him a couple of years ago and I couldn't be happier with his
    old-fashioned service and quality.
  29. aaggie
    aaggie
    Put a set of stock Vortec heads on it with timing set correct you could probably see 375-390 on the dyno.
  30. PinHead
    PinHead
    Maybe you already know this, but people are forgetting to mention that the Vortec heads will require a different intake, and valve covers too I believe. If you already have a good intake that you like, keep that in mind, because it adds to the expense.
