Raising coil springs on 55 belvedere
Discussion in 'The Hokey Ass Message Board' started by joes55belvedere, Apr 18, 2011.
  1. joes55belvedere
    joes55belvedere
    I want to raise the front of my 55 Belvedere coils by an inch or two I have seen the coilspring spacers that go under the coils but now i am seeing that people talk about using spacers on the ball joints also. Has anyone else raised there fronts on 55-56 plymouths. Thanks
  2. plym_46
    plym_46
    from central NY
    go to espo springs and things and get some new coils and seating pads, betcha there is at least 2 to 3 inches there. Then mr gasket makes the kind of spring rubbers NASCAR uses.
  3. 8FLEET9
    8FLEET9
    from MASS.
  4. joes55belvedere
    joes55belvedere
    Thanks for replys.
  5. Lower the back the wieght shift will automatically lift the front.
    I don't know that ball joint spacers will work on you belvedeer. It depends on how the ball joint is mounted. Some mount on top of the controll arm and others mount through the controll arm from the bottom.
