PPG Deltron - painters opinion needed
Discussion in 'The Hokey Ass Message Board' started by indyjps, Apr 18, 2011.
  1. indyjps
    indyjps
    Got some odds and ends projects and can buy a few Deltron off the mix rack at my paint store. Want to paint some equipment and the price is right to use good paint, nice colors too. Ive got a half gallon of detron reducer from an old paint job.
    Can I mix Deltron acrylic urethane (topcoat) DAU with Detron basecoat DBU and shoot it? do you see any paint interaction problems? will this provide a semi gloss finish?
    I should still be able to clear over this if I dont like the dead finish?
    I know I should use all new paint and spec it to what Im doing, but I would like to mess around with this new gun I bought on something useful and the paint is cheap.
  2. 1968
    1968
    Nope...you'll end up with a big mess.
    Jeff
  3. rusty A
    rusty A
    Says on the cans not to mix. Only delton base and the DAU are to different animals. Just my 2 cents
  4. DAU(Deltron) and DBU (Deltron basecoat) both mixed off the same DMD toners. DAU was meant to be catalyzed with DAU2(loooong obsolete) to create a single stage acrylic urethane finish. With base/clear becoming the standard in the 80s, the Deltron system needed to expand, so DBU was born. It's DAU converted with DBX 695 most times about 50-60% color formula and the remainder DBX695, then clearcoated with DAU82 clear(with DAU2 catalyst) OR DAU75 clear which used DXR81 catalyst(acrylic enamel hardener).
    So much for the history lesson.....:rolleyes:
    To answer your question, no, you don't wanna mix DAU and DBU.....UNLESS you cut the DAU about 50% with DBX695....at that point, you'll need to clearcoat with about any clear in the PPG line--most are compatible.
    The only safe use of DBU without clear would be DIA(I think that stands for Ditzler Interior Acrylic)--interior paint, which uses DRR reducer....which contains a catalyzing agent that reacts with the resins and makes them "gel". Not durable at all for exterior use because of the lack of UV inhibitors.
    Soooooo.......all you got a shot at is maybe some cheap basecoat! Cheap and Basecoat usually are mutually exclusive words, so you might be on to something :)
  5. voodoo1
    voodoo1
    What he said^^^^^^^^
  6. indyjps
    indyjps
    Thanks guys, kept me from making a huge mess out of my new gun.
    theres some red / maroons in DBU I can use, Perfect to paint my shop equipment with. since its an inside job Im not too concerned with high quality clear, very little UV, so I can pick up a budget clear
    Will have to verify the half gallon of reducer I have, see if its Delstar of Detron. Its from a paint job on one of my fathers cars, I know it was single stage, just dont remember acrylic enamel or urethane. I prepped it and shot all the primer on the damn thing, should remember,
