Features 48-54 Chevy/GMC trucks! lets see em ALL!!!
Discussion in 'The Hokey Ass Message Board' started by kustombuilder, Jun 19, 2006.
  1. daddio211
    daddio211
    SERIOUSLY cool Mike!
  2. 54chevytruck
    54chevytruck
    here's a few of my 54, it's currently apart for primer
  3. HotRodPopcorn
    HotRodPopcorn
    from Sparta,TN
    Great looking truck Mike. If you get a chance can you tell me what your wheel and tire sizes are? Thanks
  4. Amanda Suckerpunch
    Amanda Suckerpunch
    Mine is my avatar. Farm fresh. Tahoe farm truck. ;)
  5. SanDiegoJoe
    SanDiegoJoe
    Nicely done!
  6. dan sutton
    dan sutton
    Looking good Mike!
  7. 1lucky1
    1lucky1
    from Morgan NJ
    Looks Great Mike,Makes me miss my GMC rack.Do you have info on ch***is build?What kind of gas tank are you using.Lucky
  8. Thanks fellas! The wheels are 49 Chevy and the tires are BF Goodrich Silvertowns 670-15 - Coker, of course. The rear end is an 85 Camaro, disc brake, posi. I built the notch/bridge with parts from Suicide Doors. The rear is a parallel 4 link, and the front is a TCI mustang II with 2" dropped spindles. I z'd the front frame 1-1/2" to get it to sit right. I used Slam Specialties bags with the built in bump stops. The gas tank is an aftermarket original mounted behind the seat. I have a lot of pictures if anybody's interested just let me know. Thanks again for the kind words.
  9. HERE IS MY BURB, AND I WILL BE PULLING OUT THE 54 CHEVY TRUCK I HAVE OWNED SINCE 78 AND ITS BEEN OFF THE ROAD SINCE 85[​IMG][​IMG]
  10. wheels1950
    wheels1950
    from PA. USA
    here's mine in for sale section
    FRANK
  11. shoebox50
    shoebox50
    my 54
  12. 54chevytruck
    54chevytruck
    Hey, I wanna get rid of the fuel tank from behind my seat..what's a good tank for between the rails..what have people used? aftermarket or whatever fit..
  13. D-man313
    D-man313
    http://www.speedwaymotors.com/Polyethylene-Fuel-Cells,446.html
    I used one of these in 16gal. and mounted between my frame rails on my s10 swap. Used the fuel cell mounting straps (also from speedway) welded the top part of the mount strap to my frame. so if i need to i can unbolt the 2 halfs of the mounting straps and drop the tank.
  14. Chevy54
    Chevy54
    from Orange, CA
    I just ordered mine from Cl***ic parts...better deal and bigger tank!
  15. jaydee5150
    jaydee5150
    GMC's rock...this truck is awesome! Nicely done
  16. 54chevytruck
    54chevytruck
    Ya? good price? you running a modified stock frame? I have a C-notched stock frame an would like the tank under the bed near the tailgate
    I am hoping that by removing the tank from the cab I could get the seat to sit back a bit further..even if it's only a couple inches
  17. Chevy54
    Chevy54
    from Orange, CA
    Hmmm....its prob going to depend on how far back your frame is modified, The tank bolts undet the frame and mounts to the rear crossmember and side rails towards the notch. You could prob move that crossmember back a bit to fit and make some mounts if the back of the notch interfers with it. Ive been searching all the truck catologs and really liking what Cl***ic Parts has..plus they offer discounts if u blow enough cash with them! :eek:
  18. 54chevytruck
    54chevytruck
    well from te notch to the tailgate there would be quite abit of room, like you said tho I will have to move a cross member
    just curious what others have done? anybody got pics
  19. rusty1
    rusty1
    ...I use 67-9 Camaro & 68-72 Nova tanks under the frame behind the rearend.
    I notch the rear sill for gas cap access...only one front crossmember is needed to bolt the front of the straps to.
    These tanks are available reasonably in the aftermarket. Use a new replacement sender and get an Autometer fuel level gauge that's compatible.
  20. 54chevytruck
    54chevytruck
    I have dolphin gauges, that look like the originals. I would ***ume it would work??
  21. rusty1
    rusty1
    your gauge needs the correct ohns to work correctly.
  22. BUXMAN66
    BUXMAN66
    when i bought my dolphin gauges the fuel sending unit was enclosed as part of the gauge package as well as the oil pressure sending unit.the gauge has to work w/the sending unit,like rusty1 said.they have to read the ohm's as a team so to speak.some sending units are in a different scale from others,so they have to be a matched set.dolphin can hook you up w/the fuel sending unit to match their fuel gauge.
  23. toddwith2ds
    toddwith2ds
    from AZ
    Here is mine. bought it afew years ago with a butchered up frame, no wiring or interior. Drove it to and from work until the frame welds started to crack, then blew it apart to do an s10 swap. Hope to have a running truck by the end of the summer.... Wish me luck!!
  24. Wide Whites
    Wide Whites
    from N. Texas
    Here are some pics of mine. The engine shots are pretty old pics. But the only real change is the air cleaners.
  25. NealinCA
    NealinCA
    Made a wheel and tire change on my 49 GMC...
    Neal
    little red 50 likes this.
  26. Wide Whites
    Wide Whites
    from N. Texas
  27. kaustin
    kaustin
    Do you have a picture of under the hood i am doing the same with the 4.3L with abs just trying to get ideas for location?
  28. kaustin
    kaustin
    Great Thread!! Great Inspiration!!! Here is some of my build going on s10 frame
  29. rajcam79
    rajcam79
    from S.E. MI
  30. BUXMAN66
    BUXMAN66
    i dont believe i've ever posted in this thread even though i've been watching it for a good while now. here's mine,....[​IMG]
