Mickey thompson sportsman pro
Discussion in 'The Hokey Ass Message Board' started by guido`s 40, Apr 17, 2011.
  1. guido`s 40
    guido`s 40
    from nebraska
    thinking about running a pair of 29x12.5x15 wondering how they handle on the hiway
  2. 65COMET
    65COMET
    They work great,been running them for around six years.Not a lot of miles yet but the few have shown good traction. ROY.
  3. squirrel
    probably depends on how wet the highway is.
  4. 65COMET
    65COMET
    Jim;they actually work decent in the rain,especially for a wide tire.They are fairly sticky[soft]so I don't know how many miles you will get from them. ROY.
  5. racer32
    racer32
    I've got a set on my OT firebird in a smaller size. They're a REALLY soft rubber compound-I think the same compound as the M/T slicks. You won't get many miles out of them. They're also a "wrinkle-wall" design. They work OK in a straight line, but the sidewall will roll under in the turns. Think about this: would you run bias-ply drag slicks on the highway?
  6. 1927 Death Trap
    1927 Death Trap
    from CT
    Had them on the Nova for years. They work great. The highway is no worries. They will flat spot on ya if they sit for a while. Nothing a good meltdown won't fix.:D:D:D Be aware of how much pressure you run. They will wear out fast in the center if you have to much. Also with too much you really won't get much of a contact patch when your making a p***. I usually run between 15 and 18lbs in the Nova, lower if I'm racing. You'll find the sweet spot after a good burnout, especially if the center is worn more. Every car I have had them on seem to want different pressure levels. I'm not sure if you can get the "i" pattern any longer, but those I had the best luck with.
  7. guido`s 40
    guido`s 40
    from nebraska
    thanks for all the good info I have been debating between the m/t or hoosier quick times
  8. choppedtudor
    choppedtudor
    I run them on the rear of the t-bucket....so far so good
  9. 69fury
    69fury
    from Topeka
    i've run the ET Streets for years- 28x 12.50 15s on an 8 inch rim with a heavy car, and i never did any corner carving, but never had them bother me one bit-except rain-they're just like a slick in the rain.
    But as far as a ballooney tire on the street?- i'd run 20lbs daily, then 13 to race. 4100lb car.
    -rick
  10. 1971BB427
    1971BB427
    from Oregon
    Been running them on the back of my OT Camaro for over 20 yrs., and just put a new pair on last year. Running MT Sportsmans on my 1946 Austin 29.5x12.50x15 also. Both cars handle well, but nothing with any power will hook up in the rain. I have to be careful shifting to not break loose and get sideways. The Austin even more so than the Camaro.
    They do work just fine traveling down the road in the rain though.
  11. Deuces
    Deuces
    Just what we need... More Guido's on this site! :D Welcome aboard!........ Guido R. :D
  12. guido`s 40
    guido`s 40
    from nebraska
    you can never have to many guido's!!!!! thanks for all the input
  13. Dragsterbus
    Dragsterbus
    from England
    I ran 29x12.5x15 sportsman pros on my old street car , it was a low 11 sec car and they were great even with a spool , sportsmans don't hook up but last forever, sportsman pros hook but won't last as long , i found that Hoosier quick times hooked well but started to perish in the sidewall pretty quickly ,
    Good luck !
