halibrand weels, alu or mag ?
Discussion in 'The Hokey Ass Message Board' started by hjallle, Apr 19, 2011.
  1. hjallle
    hjallle
    from Sweden
    Hi i have bought a pair of halibrand weels ( big windows)
    on the weels it says halibrand 10,00x15 6,50 ff 2030A
    the are bead blasted a couple a weeks ago so the look like aluminum
    (but inside were the tyre is, the are dark grey)
    but i think its magnesium weels
    they are in a god condition
    is this aluminum or magnesium weels
    mvh / Hjalle
  2. Deuces
    Deuces
    How about some pictures??? :)
  3. hjallle
    hjallle
    from Sweden
    i have 3 pictures
  4. hjallle
    hjallle
    from Sweden
    ok here are one picture
  5. hjallle
    hjallle
    from Sweden
    and the other
  6. hjallle
    hjallle
    from Sweden
    and the number on the weels
  7. Smokin Joe
    Smokin Joe
    Did Halibrand even make the universals in Mag?
  8. hjallle
    hjallle
    from Sweden
    yes the did
  9. brandon
    brandon
    look mag to me... 4.75 & 5" uni'd to 5.5?
  10. roydebisco
    roydebisco
    from n.j
    looks like mag to me.
  11. hotroddon
    hotroddon
    They look like Mag, but here are some test's to find out for sure
    1 Try the vinegar test. Drop a little bit of 5% acidity white vinegar on the back of the rim. If the vinegar bubbles, the rim is magnesium.
    2 S****e some of the finish with a razor blade. S****e some of the finish off the back of the rim. Magnesium will appear silver in color. The cuttings or chips will be dusty or flaky. By comparison, aluminum will show a whiter color when s****ed and the chips will be gummy or soft.
    3 Grind the metal. If s****ing is done alone, there may not be a ready comparison or frame of reference to feel confident in the test. If there is an area large enough that grinding will not ruin the appearance of the rim (this requires a small grinder, too), put on the goggles and grind the metal. Magnesium often squeals when pressure is applied, because it is a hard metal.
    4 Test the density. Density is specific and constant, so any size sample will work to test density. Determine the m*** of the sample in grams. Drop the sample in a beaker of water to determine the volume of the sample with a water-displacement test. Divide m*** by volume. The density of magnesium is 1.74. By comparison, aluminum's density is 2.7.
    5 If all else fails - throw it in a fire, if it erupts into an intense bright white flame with lots of smoke - you just lost a very expensive magnesium wheel
  12. hjallle
    hjallle
    from Sweden
    yes brandon thats right about the 4.75 & 5" uni'd to 5.5
  13. 65PANELRAT
    65PANELRAT
    5 If all else fails - throw it in a fire, if it erupts into an intense bright white flame with lots of smoke - you just lost a very expensive magnesium wheel[/QUOTE]
    LMAO!
  14. hjallle
    hjallle
    from Sweden
    must test the vinegar test
  15. hjallle
    hjallle
    from Sweden
    if its mag what price range are the in ?
  16. hjallle
    hjallle
    from Sweden
    yes they are bubbling with vinegar ( and turning dark grey on the spot with vinegar)
    puhhh then i dont have to throw them in to the fire LOL
  17. woodienut
    woodienut
    from So.Cal.
    Damn it would have been one HELL of a fire!!!
  18. hjallle
    hjallle
    from Sweden
    the weels are going on a front engine dragster
  19. mgtstumpy
    mgtstumpy
    Doesn't polished magnesium tarnish a lot quicker than aluminium if polished?
  20. lol beat me to it
  21. Shaggy
    Shaggy
    from Sultan, WA
    Hit it with a grinder in a not noticeable spot
  22. Deuces
    Deuces
    Mag also turns dark if you let it sit in hot water...
  23. hjallle
    hjallle
    from Sweden
    no grinder for this weels
  24. Ron Mayes
    Ron Mayes
  25. hjallle
    hjallle
    from Sweden
    thanks ron, do you now what they seeling for in this condition?
  26. DE SOTO
    DE SOTO
    If they are going on your Dragster, Does it matter what the are Selling for ?
    If you got them Cheap .... Be Happy :D
  27. hjallle
    hjallle
    from Sweden
    DE SOTO you are so right
    thanks
