c4 help
Discussion in 'The Hokey Ass Message Board' started by onebadrambler, Apr 18, 2011.
  1. onebadrambler
    onebadrambler
    Just bought a 77 ford Granada from a friend who had the vacuum modulator replaced because it was leaking atf into the vacuum hose.The tran`s shift`s fine but the shift point`s are way off(To soon)Can anyone help me with the correct color i need for my modulator.
  2. vrod64
    vrod64
    from Katy,Texas
    ***uming it is a stock motor ? Any Vaccuum leaks ?
    Cam selection (lack of vaccuum) and vaccuum leaks can effect shift points.
  3. Smokin Joe
    Smokin Joe
    ****can it and send me the spindles for my 60 Raunchero!
  4. onebadrambler
    onebadrambler
    Your not the first person to say that.Now i no were all the Granada`s went.......
  5. spiffy1937
    spiffy1937
    from Florida
  6. 26 roadster
    26 roadster
    most new mods are adjustable, try cranking it up with a small screwdriver
  7. 63feuni
    63feuni
    check for missing modulator pin
  8. Jalopy Joker
    Jalopy Joker
    bands may need adjusting too. how does the fluid look? how many miles on it? might as well change fluid and filter to be on safe side. original trans? when you sell spindles you can make some $ on rear end too -Ha!
  9. d.reese
    d.reese
  10. onebadrambler
    onebadrambler
  11. d.reese
    d.reese
    They were a real big help in me R&R a FMX shifter rod seal in the car!
    Good luck!
