where can i find a set of 4 old style valve cover breathers they used on old blown drag cars? my 55 has a 671 blown 800 hp 468 with smaller push in oval breathers but the drip oil down my valve covers everytime i drive it. will the old style help this problem? i want them for the vintage look anyways..but being able to drive it without a oil fire would be great too. if anyone has 4 or knows where to buy them at a decent price let me know.
If theys dripping oil, you have a internal problem or your crankcase vent system is not working properly
Your valve covers probably don't have baffles in them, or the baffles are not very good. Factory big block valve covers have pretty fancy baffles under the pcv/vent holes....they're necessary
i picked up a set of 'tall' style from moon and they work great on my 6-71 set up, got a pic in my Vette album if you want to see what they look like
Blown motors generate more crankcase pressure and will want to push oil out the breathers. The best fix is a stand off or spacer to get the vent up higher, this lets the oil vapor have more time to condense back into oil before the pressure is vented off. If you get the old type you are looking for, I would make a spacer for them as well and a little foam stuffed inside to speed up the condensation process. Back in the good ole days you could watch the cars in AA/FD = top fuel front engine dragsters, and see shop rags duct taped to the breathers and the back of the drivers hand. By the final round they were blowing oil everywhere. I think you can figure out what the rag duct taped to the hand was for.
I run Moon breathers on my blown SBC with no leaks. The valve cover needs to have baffles under the breathers.
i got them..it was not cheap! moon was way too much so i got them from the shop i bought the blower from big als toybox...wich i said id never do buisness with again, but he had them in stock and gave me a deal $200. for all 4,they look great,all billet but have the vintage look i want. now i just hope the keep the oil in.
I just picked these up just for the breathers, is that the style you are looking for? Edit; I see you are good to go!
Exactly what Squirrel said. Also if you are running an 800 hp blown 468 you probably need a va***m pump on the crank case. You can set one up on the cheap with a smog pump off of a '70s Ford.
yup, friend of mine from back in high school has a blown 454. he runs a smog pump off a 351m 400 from a 77 thunderchicken
I bought these valve covers recently at the swap meet, mainly because of the breathers they had on them. But after looking them over I decided the breathers and covers were best left together.
