Make power with low comp. 440 ?
Discussion in 'The Hokey Ass Message Board' started by cornpatch, Apr 20, 2011.
  1. cornpatch
    cornpatch
    I have a low mileage 1978 440 with low comp engine (low 8's stock.) I dont want to take off the stock heads (452) or replace the stock pistons. I will use a Pertronix ignition for a points style dist. with their stock looking coil.
    I do have Edelbrock performer RPM intake ,750 Holley, using stock 383-440 magnum exhaust manifolds, and can change the valve springs if needed. Car is 3800 lb. 4 speed, 3:55 rearend.
    What cam specs would give me the best performance with this low compression engine? I know what lift, duration, overlap means, but not good with knowing just hjow the different combos work for specific purposes.
    Thanks for any input............MO
    Deuces likes this.
  2. DirtyThirty
    DirtyThirty
    from nowhere...
    Why not just mill the heads a bit, before trying to go with anything other than a very conservative cam choice, due to loss of cylinder pressure??
    It's fairly cheap if you have a decent machine shop buddy, I'd do that first I imagine.
  3. joes55belvedere
    joes55belvedere
    Years ago I built a low comp 440 stock 452 with mopar hipo springs mopar 284-484 cam Holley street master, 750 holley, 1/78 headers 3.91 gears and 3500 convertor. I dialed in the suspension and tuning I ran a best of 11.89 at 115mph. It was a consistant low 12 sec car. Weight will hurt you a bit I was around 3400.lbs. But with the stick and 3.55-3.91 and tuning it will run. I would go with a slightly smaller cam, something in the 270-274 range.
    Deuces likes this.
  4. cornpatch
    cornpatch
    Yes, I do agree that milling the heads would make a big difference, but I just dont want to do that at this time. This will be a temporary engine and The parts I have can be used with my 413 build, later. For now, I want the best performing cam with the engine comp. I have. Thanks for your input................MO
    Deuces likes this.
  5. ddawg16
    ddawg16
    from So CA
    When you say "Low 8's", do you mean Compression ratio? If your talking ET's....that would only be possible in the 1/8th mile....
    Anyway.....changing your cam is not really going to gain you much if anything. My best friend on a 68 charger with the same engine....stock...p*** anything on the road except the gas station...ate a quart of oil every night....but the ***** was fast....
    Without changing other items....not much else you can do....those engines were pretty much dialed in. To really gain anything, you also need head work....exhaust work....etc.
    If your looking to improve your quater mile times....re-gear.....that will do more for you than anything else.
    But if you really want to change the cam....go pull up the specs for the cam manuf you want to use. They will list the power range for each grind...decide where you want your power to come on and how high you want your RPM's to go.
  6. fiveohnick2932
    fiveohnick2932
    from Napa, Ca.
    Good question?
    I have a late 70s 440 with low miles on it and I just can com up with a way to do it right using those stock parts even with using a .018 head gasket. Those motors are actually 6.2:1 if you do the math with a .020 head gasket. I dont know where the factory came up with that 8:1 stuff but the math just doesnt jive!
    Hughes engines sells a sweet cam for low compression motors called the whiplash.
    www.hughesengines.com
    Im going to put some different pistons in mine (to get around 9-9.5:1 compression) along with a forged crank I have. I have the Hughes 1928BL cam for it, ported 67 GTX heads, performer RPM intake and 750 Holley. Should get over 400 hp and over 500 ftlbs torque.
    Deuces likes this.
  7. pcterm2
    pcterm2
    before you do anything check with Dolmetsch here on the board.the man knows alot about mopars
  8. bREWcITYbIRD
    bREWcITYbIRD
    I would go with a cam grind from Hughes Engines. Maybe their Whiplash cam:
    http://www.hughesengines.com/Index/...V2hpcGxhc2ggTXVzY2xlIENhciBjYW1z&partid=25116
    Most of the new cam designs are made to build more cylinder pressure with lower compression engines.
    The 452 heads are good heads they are basically the 69-70 906 heads with hardened exhaust seats. The magnum exhaust manifolds flow good. The Performer RPM intake is a great intake, but on a 440 usually seems to like a 850. The only other thing would be the ignition this should have had electronic ignition from the factory. The stock distributors in these years are pretty much the same as the Mopar Performance units they sell today, so if you have it i'd stick with it.
  9. cornpatch
    cornpatch
    I am very familiar with Don, I am hopeing he chimes in on this . I asked him about this a while back and his basic reply was to mill the heads 60 thou. In this particular case, I don't want to do that..
    . Thanks alot folks, all input is appreciated.....................MO
    Deuces likes this.
  10. bREWcITYbIRD
    bREWcITYbIRD
    From what ive seen the pistons on these later motors are .100 - .120 in the hole which should come out to 7.9:1-8.2:1 it you were to put a set of 915's (67 GTX HP) heads on a later motor it should bump the compression a full point which would put you at 9.0:1 without a piston swap.
    Gasser 57 and Deuces like this.
  11. fiveohnick2932
    fiveohnick2932
    from Napa, Ca.
    The closed chamber heads are around 75cc and lets say you mill those to 70cc you would only get it up to 6.8. Not woth the effort pluss you have hosed a good set of 452 heads. Its too bad those pistons a cast because it would be a perfect candidate for a street 671 blower motor!
    Deuces likes this.
  12. fiveohnick2932
    fiveohnick2932
    from Napa, Ca.
    .100-.120 would be nice but ive miked mine several times and they are .150 in the hole. Ive used several calculators on line and done it on paper and they all come out the same.
    Deuces likes this.
  13. cornpatch
    cornpatch
    I am enjoying the input. I don't know where to look to find factory compression ratio figures for a 1978 440 engine. The only source I did find, quoted ( I think) 8.2 :1 And I do not know what thickness head gasket that would be with. I would be shocked to find that it was substancially lower than THAT. .........................MO
  14. das858
    das858
    Like several others have suggested, the Hughes whiplash cam is the way to go on low compression 440's. If it was mine I would bite the bullet and put 9.5-10.5 compression pistons in it, but I understand being on a budget.
  15. el Scotto
    el Scotto
    from Tracy, CA
    I have a forged crank 440 engine out of a '73 motorhome so I'll stay tuned to this thread. I don't want to toss a bunch of money or time at it, but I love burnouts and this engine may end up in my Model A.
  16. cornpatch
    cornpatch
    We a difference in opinion here and I think you are both right. My bet is , the 440 with 150 thou below the deck is below a 8 :1 comp. ratio because it is a motoehome engine. I'm thinking at 110-120 thou below the deck would be the 8.2:1 ratio , Both having the same cc heads.
    Thanks for the input folks, Please more replys. I am learning some more 440 things here. I would like to have some more cam specs and what they should accomplish..............MO
    Deuces likes this.
  17. fiveohnick2932
    fiveohnick2932
    from Napa, Ca.
    My .150 motor is out of a 1975 pickup, probably a sweet gas ****ing low power rig when new :D
    I dont know why you would have less compression on a motorhome. Those motors had heavy duty rods for a reason.
  18. fiveohnick2932
    fiveohnick2932
    from Napa, Ca.
    Ok guys! DO I FEAL STUPID NOW!!
    I had "F"ed up this whole time and had fogot to put a zero some place!
    Anyhow,
    88 cc head
    flat top piston
    .020 gasket
    4.35 gasket bore
    4.32 bore
    .150 in the hole
    3.75 stroke
    = 7.98 compression (we can call it 8:1)
    When choosing a cam for compression you want to look at the intake closing point to up your cylinder psi. The "range" i found from reading a hot street cam is between 7.5 and 8.5 dynamic compression ratio (found by using intake closing point @.050 + 15 deg and your rod length). Anything beyond 8.5 is time for race gas.
    So I plugged in my Hughes Engines 1928BL cam that has a 52.5 closing point and the 6.768 440 rod and came up with 6.93 dynamic compression. With my closed chamber heads it gets me to 7.5. Too low for me, thats why im changing my pistons to get it up to 8+ dynamic. The whiplash cam has a good intake closing for dynamic compression and more duration than mine which makes it a better hot rod cam. There are some good videos on youtube and the Hughes website. Check it out!
    Deuces likes this.
  19. Problem with milling the heads is that the rockers are not adjustable. The only adjustable rockers for your setup from MOPAR would be for a 426 max wedge, pretty basically they are made from unobtainium. The other option is after market rocker arms not unobtainium but made from expensium.
    WEe have used the 383 road runner cams with good success or MOPAR purple cams the middle of the road or the tamer version hydraulic cams with the low compression motors with pretty good success.
    Either can be purchased from your favorite catalog speed shop at a reasonable price.
    Deuces likes this.
  20. el Scotto
    el Scotto
    from Tracy, CA
    I heard the Engle K56 cam is pretty nice in a low compression 440 with an intake and headers, but I have never looked it up to see what the specs are.
  21. cornpatch
    cornpatch
    Thanks for the input folks. I haven't been on the board for a while. Is the comp ratios in your last paragraph what you intended? My confusion is probably cause I don't know the difference between static and dynamic compression.
    I know that a 413 Motor home engine has dished piston tops and are low compression. I have bot seen a 440 with a dished piston top, so would guess they lowered the compression by puttimg it lower from the deck. Thanks for you'uns help and I welcome more input...........MO
    Deuces likes this.
  22. Perry Hvegholm
    Perry Hvegholm
    Old *** thread, but i'd be curious how the OP's build turned out. I've built up a number smogger 440's for street cars. Most recently, I found a Craigslist seller looking to sell the entire drivetrain out of a 75 New Yorker. Car was cream puff. He made me an offer I couldn't refuse and carted off the motor, trans, propshaft and Suregrip equipped 9 1/4 rear.
    I opened the motor up and found a re-builders tag. Super clean inside, perfect crosshatch, no ridge, pristine bearings, etc. I ****oned it back up, fed it a Comp XE268 cam, Eddy RPM, 800 AVS carb, headers and topped it all off with a set of Stealth aluminum heads (with upgraded hardware and seals). Stealth heads being closed chambered will buy you close to a point in comp. The whole thing cost me less than 3 grand, including the acquisition of the motor. In a 3800 lbs car with a stock converter and 3:55's the car has turned in high 12's. Its not a race car, but if I had spent the extra grand to get 440 Source's ported Stealth heads I think i'd break into the 11's with this one. This is just one of many Smoggers that I put together over the years.
    The whole point is, typically when you broach this subject, posters begin chiming in with statements like "you gotta get those pistons out of there" and "get that compression up". It seems everyone would love to push you toward a 10k stroker motor, but you can make serious power with a smog era mill without resorting to scorched earth policies as regards the rotating ***y. Cam choice is critical. Shorter duration helps maintain compression and keeping lift below .490 gross works best for a street motor. Sticking with stock log exhaust manifolds on a Mopar BB is really just ******* directly into the wind, though.
    Deuces likes this.
  23. Budget36
    Budget36
    Would it have not been more cost effective to change pistons, and maybe pull the die grinder out on the iron heads?
    I'm asking (why I looked at this thread) because I have a '76? Winnebago 440/727 with low (40K) miles I'd like to pep up without getting too deep into my wallet.
    Deuces likes this.
  24. Rocky
    Rocky
    Classified Editor
    My buddy, Tom has a 74 duster with a 78 motor home 440 and a 727. Somebody before Tom put a mild cam in it and it's pretty stout. Runs fairly impressive....Oh yeah, it's also got a chevy big-cap H.E.I distributor....looks really outta place on that 440 but seems to work fine.
  25. Deuces
    Deuces
    I thought all 440 cranks were were forged steel..
    I could be wrong....
  26. Frankie47
    Frankie47
    from omaha ne.
    Cast 440 cranks are a real deal.
    Deuces likes this.
  27. Eh-Bone
    Eh-Bone
    I remember hearing the pushrods on a ‘67 383 block are shorter than those of the ‘69 and up B blocks.
    Is this in fact true?
    ....if so could you not use the B(383) block pushrods in the RB(440) block, thus allowing the head to get milled (difference in B-RB pushrod lengths) to raise compression?
  28. el Scotto
    el Scotto
    from Tracy, CA
    I used the XE268 camshaft and found it far too small, I ended up replacing it with a Mopar Performance .509/292 camshaft and was super happy. But that was years ago. Rest of the combo was headers, 850 DP Holley, Performer RPM and ported 915 heads. Never got it to the track but it was definitely stronger.
    My 1970 Challenger with a stock ‘68 375 horsepower 440, headers, Performer RPM and 750 DP Holley has run a best of 13.9@101 MPH on street tires, it really needs a better cam, better tires and a larger carb to go faster but I haven’t played with it in years...
    Deuces likes this.
  29. Frankie47
    Frankie47
    from omaha ne.
    For a short time there was a limited run of 383 RB Blocks from 59 to 60 and in 68 they started using 440 heads on 383 magnums not sure if that would be enough to not interchange pushrods on the standard 383.
    Eh-Bone and Deuces like this.
  30. II FUNNY
    II FUNNY
