NEED a GOOD 305 BLOCK in the N/S CAROLINA AREA!!!
Discussion in 'The Hokey Ass Message Board' started by 38FLATTIE, Apr 19, 2011.
  1. 38FLATTIE
    38FLATTIE
    from Colorado
    A friend damaged his 305 block, in his record setting LSR car. He desperately needs to find a good block ASAP, so that he can run in May.
    So, I need a good used 305 Block that can be cleaned up at max 30 over.
    PM or email baharley4me@aol.com
    Thanks in advance!
  2. edweird
    edweird
    yea i've got one. he can have it for free. its from an 86 firebird and i'm pretty sure its standard bore. come get it.
  3. 38FLATTIE
    38FLATTIE
    from Colorado
    I just sent you a pm!
  4. Cool! Charles is a good guy and chasing ECTA points. That block is needed!
  5. truckncoupe
    truckncoupe
    Hey 38FLATTIE, how you doing? :D
  6. You might want to verify which type of 305 buddy is looking for. 86 should be the one-peice rear seal (which means different crank) as opposed to the earlier 85 and down 2-piece rear seal. Different crank means different flywheel mounting pattern on the crank, it might or might not matter in this case.
  7. 38FLATTIE
    38FLATTIE
    from Colorado
    Ken, Life is good! You?
    Borntoloze, thanks for the info!
  8. nitrojoe
    nitrojoe
    from Midway,nc
    you can have my 307 in my ramster!!
  9. 38FLATTIE
    38FLATTIE
    from Colorado
    Thanks everyone! Charles has a block on the way, and will make the May meet!
