schroder steering
Discussion in 'The Hokey Ass Message Board' started by coopsdaddy, Apr 15, 2011.
  1. coopsdaddy
    coopsdaddy
    from oklahoma
    I see they have them with the steering coming out of the top and bottom,which one works the best in model a's.
  2. silent rick
    silent rick
    i don't think schroeder made them both ways. more than likely, you saw someone running one meant for right hand drive upside down so it comes out the driver's side.
  3. Mr48chev
  4. silent rick
    silent rick
    maybe i should elaborate. they came in both left and right hand drive. they are intended to be run one way more likely to keep the gears in the lube. the one i had used a heavy grease. i don't think it mattered much if it was run upside down. one drawback to running it upside down would be the shaft that went to your steering wheel might be in the way of your pedals because it now hangs below the cross shaft that goes out to your pitman arm. or did i just confuse you more?
  5. silent rick
    silent rick
    here's a pic of one intended for right hand drive flipped over and ran out the other way.
  6. Da' Bomb
    Da' Bomb
    Mine runs on the top, exiting the cowl on the drivers side. If it's low, it's probably going to make for some interference with the feet.
    Pat
  7. coopsdaddy
    coopsdaddy
    from oklahoma
    Ok,i learned something,how bought some mounting pics..
  8. GARY?
    GARY?
    Here ya' go.
  9. coopsdaddy
    coopsdaddy
    from oklahoma
    How bought with swinging pedals?
  10. Kirk Hanning
    Kirk Hanning
    .....with Wilwood hanging clutch/brake pedals.
  11. sdluck
    sdluck
    Dirt cars ran them on left side pavement cars on right side
  12. coopsdaddy
    coopsdaddy
    from oklahoma
  13. lakester47
    lakester47
    Here's another example of swinging pedals. The pedal mount also does double duty and mounts the steering. This is a right hand steer version.
  14. coopsdaddy
    coopsdaddy
    from oklahoma
    Nice setup lakester
  15. lakester47
    lakester47
  16. AJofHollywood
    AJofHollywood
    If someone could elaborate on this, I would appreciate it.
  17. AJofHollywood
    AJofHollywood
    Also if anybody knows, Schroeder steering ***emblies are sometimes attached using connecting rods at each arm. What engine do those connecting rods come from?
  18. coopsdaddy
    coopsdaddy
    from oklahoma
