Incredible welds
Discussion in 'The Hokey Ass Message Board' started by rusty f100, Oct 6, 2008.
  1. MedicCustoms
    MedicCustoms
    I just got a tig. I need alot of practice befor I even think about posting and still won't post. Some of you guy's are artist. Just pure talent....
  2. daddylama
    daddylama
    jdustu: man, you lay some purdy p***es!
    i used to spend my days with a TIG in hand... foreman of a welding/fab shop. it was pretty rad.
    now, years later i spend my days in a cubicle... or worse, a board room in some damn meeting, usually led by some ***hat (me).
    sure do miss being a fabricator, though i spend a couple hours/day doing it for myself and my own projects.
    to any young bucks looking at this thread: don't dismiss a good trade and just head to college. the loss of industrialization in this country is heart breaking... forget college and go be a welder.
  3. My dad welded this thing together in a 2 car garage with an Oxy Acetelyne outfit in 1963.Crashed it at Lions in 66 & bent it up good but not one weld broke.
    I still have a piece of a 2" X 2" tube frame he made for our old gate.
    The welds were awesome.
    The B&W pic is when it was brand new in 63 & color shot was 65 0r 66.
  4. Here it is without body,,,kinda funny lookin
  5. The37Kid
    The37Kid
    jdustu, your welds look perfect, every time I see TIG welds like that I wish I had the funds to go out and buy a TIG unit. It's been 22 years since I TIG welded, wonder how long it would take to get back in form. Back then the unit the shop had was set up for aluminum only, and I was doing aluminum body work. I've always wondered how it would be to TIG steel. I've had an offer to try a TIG unit a friend has, so I guess having my own helmet would be the first step. What helmet would you recommend?
  6. I have a Speedglas, they are good helmets. Oh, and Hi Josh!
    James, Aka Rudy
  7. dallasdrifter
    dallasdrifter
    from dallas tx
    I work for a transportatoin company that makes hundreds of millions and they won't even buy us a new arc welder or mig. I wouldn't mind trying tig- but my co worker said it's a ***** and he is a former metal shop fab guy. I am a decent mig welder, but can't aluminum weld for ****. gets cold too quick. that's what grinder's are for though, right? ok, I am having deja vu. weird...
  8. Gojeep
    Gojeep
    from Australia
    Does it matter which model as the prices are from $150 to $400?
  9. hartmen
    hartmen
    i have to get the camera now and post pictures of my welds....
  10. bonez
    bonez
    from Slow lane
    Ok, makes perfect sense.
    I do both circular, half moons, and even move-pause-move, dependin whats the easiest on each particular session, and yeah, i can see the freeze spots clearly through the gl***, so i guess the frezee spots are too tight makin them less obvious, and infact they are, my shakey hand dont help also :D..
    As forthe root its something i do too, so i simply didnt know how it was called. great!
    So, thanx so much, now i'll practice a couple months, get a cleaner camera and then i'll post the results.
    THANX so much again.
  11. jdustu
    jdustu
    from Detroit
    I think we are on the same page :D : http://watchtheprettylight.tumblr.com/post/4245875467/have-fun-in-your-cubicle
    That is wicked man!
    Hey Rudy!
    Currently I've got a couple Jackson Nexgens and a couple Speedglas helmets. I had the Nexgens forever, when one of them started going bad I decided to try the new Speedglas. The Nexgens are in the mid $200. The Speedglas 9100** is around 350, but the screen is big and the headgear is ridiculously comfortable. The other one is a 9002 I think, that's in the high 200s.
  12. jdustu
    jdustu
    from Detroit
    Trying to do some different things with aluminum.
  13. hartmen
    hartmen
    how thick piece of aluminum is that you are using? that is one wide bead.
    here are a few of mine. aluminum, ss, and regular mig.
  14. hartmen
    hartmen
    how do you eliminate the white smoke around a tiged aluminum weld? been trying hard to get rid of that stuff. im the technical welder at my work and get paid good at it. always looking to improve. i know im not the best but better than some. 3 yrs epxerience....6months under my belt professinally.
  15. hartmen
    hartmen
    im using 50-50 argon and helium....if it matters on the aluminum. on the steel and SS. steel i use the same also. any recommendations?
  16. hartmen
    hartmen
    i work on high end semi trailers. for nascar drivers and such. right now im working on one for patrick dempsy. ...i think that is how you spell his name.lol
  17. 392_hemi
    392_hemi
    I believe the white around the weld is where you burned through the oxide coating. Not sure there's any way around that, although you could probably play around with settings to minimize the area.
  18. jdustu
    jdustu
    from Detroit
    It's a couple of 1/4" pieces. Just practice, obviously the bead is a little overkill for that size :D
  19. hartmen
    hartmen
    the smallest ive gotten the white smoke by adjusting the settings is about 1/8" away from the metal. before welding i always prep the metal by wiping it all down with Alcohol
  20. paco
    paco
    from Atlanta
    Nothing wrong with aluminum overkill ... I dig it.
    PACO
  21. jdustu
    jdustu
    from Detroit
    A hambr sent some parts for his '32 to me for some weldage.
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
  22. jdustu
    jdustu
    from Detroit
  23. paco
    paco
    from Atlanta
    Thanks for the info ... pix too. As you might know I do more aluminum than steels so another welders perspective is always a treat.
    I don't think I've every NOT learned something from a person that knows his craft well.
    Thank you.
    PACO
  24. bonez
    bonez
    from Slow lane
    Jdustu, i have a question for you, or any pro welders actually.
    Im thinkin of making my own air tank, i did little reasearch and found out i will be safer doin it out of thick wall round tubing w/ roundy cap ends instead of the 2x6 i was thinkin originally.
    What would be your advice b4 i adventure into something like this, i mean technique wise. thanx a lot.
  25. jdustu
    jdustu
    from Detroit
    How much pressure? I'm not gonna lie, do it yourself pressure vessels is something I don't recommend. Too much at stake.
    Do you have an experience doing open root welding?
  26. vtwinpartss
    vtwinpartss
    from NOR CAL
    I get to play with laser welders
  27. hartmen
    hartmen
    wow that is tiny!
  28. NOTCH
    NOTCH
    laser welds!?! dang nice!
  29. daddylama
    daddylama
    laying dimes...
    wait...
    what's 1/1000 the size of a dime?
    laser welds can look awesome. ran a machine for a while... some cool stuff
  30. DECKARD sr.
    DECKARD sr.
    holy ****! i did'nt see the penny at first, that is pretty darn cool.
